Old 11-12-2008, 01:58 PM   #1
Hart_Rod
Hart_Rod's Avatar
Power steering question
I'm new to the 4 X 4 scene so bear with me, . I'm looking a buying a 1968 4 X 4 suburban. It currently doesn't have power steering, but I think I would like to add it if I purchase it. It has the "old style" knuckle (??) front end. How difficult will this be? What about a disc brake conversion? Should I just get another front axle? Any help would be appreciated.
R
Hart_Rod is offline   Reply With Quote
Old 11-12-2008, 02:19 PM   #2
jrdv
jrdv's Avatar
Re: Power steering question
Rob,
I don't know much about the 68 4x4's, but I would just swap the axle for one with disk brakes. I also think you need an adapter that goes on the frame for the power steering---someone correct me if I'm wrong.
Welcome to the 4x4 world.
john
jrdv is offline   Reply With Quote
Old 11-12-2008, 03:38 PM   #3
Hart_Rod
Hart_Rod's Avatar
Originally Posted by jrdv View Post
Rob,
john
Not quite there yet, I still have to work a deal, . I just wanted to get some information before committing........
Old 11-12-2008, 06:09 PM   #4
CPNEJR
CPNEJR's Avatar
the 68 front end should be a closed knuckle dana 44. your best bet would be to swap to a open knuckle front from a 71-72 because it'll have disks. also a corp 10 will fit but i don't know what is involved with that. as for the power steering you'll need an adapter plate as said above
(Only) Member of the CPNE Fan Club Aint that the truth
67 C-10 350 with 3-speed tranny and 308 gears swb step
82 Z28 Camaro 355 small block over 350 hp and a borg warner super t-10 (blown engine)
72 Chevy K20 Suburban (future project)
70 Chevy K20 now 68 GMC K2500
2003 Chevy 2500hd ccsb 4X4 (daily driver)
CPNEJR is offline   Reply With Quote
Old 11-12-2008, 06:59 PM   #5
Hart_Rod
Hart_Rod's Avatar
Thanks for the info guys. Any pictures of the adapter plate?
Old 11-14-2008, 11:50 AM   #6
LILRED66
LILRED66's Avatar
Here is one that we use, as well as a complete kit...these are specific to the '60-'66, so I don't know for sure about the '67-'72, but hopefully this will get you headed in the right direction. www.carsteering.com is a good source for parts for a power steering conversion, as well as, you favorite local auto parts store (FLAPS).
I hope this information is helpful and good luck with your project.
LILRED66 is offline   Reply With Quote
Old 11-14-2008, 01:32 PM   #7
Hart_Rod
Hart_Rod's Avatar
Thanks LILRED. Whats the price of that kit?
R/
Old 11-12-2008, 09:51 PM   #8
msgross
msgross's Avatar
check out the last couple of pages of my build thread... new axle is better, (any chevy solid axle will bolt right in, I ran a 1982 10bolt) if it has the flat frame like mine then you need the conversion bracket...
post #11 for you...
http://67-72chevytrucks.com/vboard/s...33#post2916233
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 11-12-2008, 10:01 PM   #9
joe231
joe231's Avatar
i think it is the same as the '60-'66
(yeah just saw your build msgross)
it is the same, and Classic Parts is always $59.95
http://www.classicparts.com/1960-66-...info/76%2D979/
CHEVY ONLY
Old 11-14-2008, 03:36 PM   #10
dinotruck68
dinotruck68's Avatar
all you have to do is find a good lil donor truck with everything on it..
my 68 has a corp 10 of an 87 burb as well as the whole powerstering set up... an everything works pretty well
dinotruck68 is offline   Reply With Quote
Old 11-21-2008, 04:38 AM   #11
hereinmissoula
not to be rude... but you would be crazy to actually swap a 10 bolt in right... i have broke 3 of those and pounded on 44's with 35" tires...
i know the brakes are nice and power steering setup but i wheel my ride and i hate 10 bolts...
why not a 44 out of a later model.... i realize 60's are expensive...
hereinmissoula is offline   Reply With Quote
Old 11-21-2008, 09:49 AM   #12
msgross
msgross's Avatar
I must be crazy then too... of course I take care of my trucks and don't attempt to do things that they aren't made for... (ie 35" tires off-road with a 1/2 ton axle)
Rob, I have a link at home for a setup like that.. They were selling it for about $350-$400 for the complete kit at Carlisle... I'll PM that this weekend...
The Garage:
Old 11-21-2008, 01:14 PM   #13
hereinmissoula
sorry... was sharing some experience and believe i worded my reply as a question, as not to be rude...
this is the 4x4 section, not the comfort section, so i was trying to give a little advise based on 4x4'ing... cost's money to switch to these parts and i bet you could find a 44 almost just as easy... not tons better, but better...
10 bolts have very weak axles... even the aftermarket ones don't hold up very well....
if your just gonna drive your truck on road then i guess a 10 bolt will do great...
JMHO
msgross... your just jealous i have a 3/4 ton.... lol jk....
Last edited by Liz; 11-23-2008 at 10:59 AM. Reason: use the edit button instead of double posting
