Old 11-12-2008, 06:59 PM   #1
orbot
orbot's Avatar
Warn hub installation help
So i have automatic hubs now but when i went to 2hi sometimes it seemed like it wanted 4 hi again, wheels stuck, so figured it was bummed hubs, had store credit with 4wheelparts bought the warns 9790's
Now i was installing one side when i noticed it had no lash (as the instructions say) so toch it off, now heres what i took off in the same order
reatiner clip
spacer
adjusting nut
lock ring
but i see in the chevy manual book that the retainer ring goes after the spacer, i had it the other way around, does this affect???
ok so going back to the instructions, it says to take the lock ring off and put everything back but i couldnt due to a dimple on the following nut so the only way was to not to put the spacer in, and that way i got a tiny bit of lash for the axle retainer clip to go in, in fact with the spacer in the clip wouldnt fit.
Did i hook it up right???
Have only done one wheel.
orbot is offline   Reply With Quote
