Old 11-13-2008, 03:06 PM   #1
badriand
badriand's Avatar
Anyone make thier own trac bars?
Any ideas, got mine dropped 5 in the rear thought maybe i could cut the bar in half and make some sort of adjustment make up for the drop.
badriand is offline   Reply With Quote
Old 11-13-2008, 03:28 PM   #2
vin63
It's Better With Nitro
vin63's Avatar
Re: Anyone make thier own trac bars?
I did...since I'm going with a sheetmetal Ford 9-inch rearend housing, the back of the housing extends quite a bit further than a factory-style housing. This required me to move the panhard/track bar and mounts further back, and I fabricated an elongated J-bar-type of panhard bar with a threaded rod end (poly bushed) that mounted to the back of the passenger side trailing arm. The J-bar design was used so itwould pass under the back of the housing and to accommodate the extreme rear drop. I used chassis tabs to fabricate my mounts to the frame and trailing arm. I hadn't welded in the gusset on the back of the trailing arm when my wife snapped the photo, but it should give you an idea of what I did. I hope this helps.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 11-13-2008, 03:31 PM   #3
badriand
badriand's Avatar
thanks vin63, where did you get the poly threaded ends from?
Old 11-13-2008, 04:14 PM   #4
kizer
Its Deja Vu time again
kizer's Avatar
I suppose it just depends on where you look. Being from the Offroad world I have a tendacy to well look at those places.
http://bluetorchfab.com/store/index.php?cPath=87
http://www.rodendsupply.com/
http://www.currieenterprises.com/ces...nnyjoints.aspx < --- talks about different joints
Im sure there are tons more. I just did a quick look on Google. Of course there are different types of rod ends.
Johnny Joints, cartidge joints, Heim joints, poly, rubber. Just depends on what your poison is I guess.
Its not pretty but its mine to figure out.
The build / The Photos / Build Diary
kizer is offline   Reply With Quote
Old 11-13-2008, 04:17 PM   #5
vin63
vin63's Avatar
Mine were left over stuff from past projects that I cobbled together. You can get them from most of the race and street rod component retailers, such as Speedway Motors, Art Morrison, Applied Racing Technology (A.R.T.), etc. Look/ask for the polyurethane-bushed rod ends. Or, you can buy a panhard bar (new or used) and modify it - these usually come with the ends and bushings.
Old 11-13-2008, 04:23 PM   #6
badriand
badriand's Avatar
Thanks guys , forgot to mention i am cheap, 40$ per rod end vs. 59$ for whole trac bar from cpp, i think i got my answer.
Old 11-13-2008, 04:30 PM   #7
kizer
kizer's Avatar
Your Cheap, heck I got my entire truck for $400 and I might of landed a 350 for $150.
Pays to be thrifty and shop. Sometmes you might get a better deal to buy a new setup or build depending on the quality of the final product of course.
Old 11-13-2008, 07:53 PM   #8
shortbed70
shortbed70's Avatar
Made mine from solid 3/4" round stock then made the ends and made it solid for now no bushings then made a quickie mnt for trailing arm to get me buy till now. This was so I could drive it back home and now it sets with nothing holding rearend center because it won't be moving for a while. Once I get the drop done I will make new mounts and make the bar straighter or I might fab some kind of watts link.
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 11-13-2008, 09:29 PM   #9
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
If you want some precision...you could always go with a Watts....
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 11-14-2008, 02:12 PM   #10
slepysal
slepysal's Avatar
Watts the hell is going on ? LOL John that is some crazy work !! Nice!
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 11-15-2008, 04:02 AM   #11
kdrodworks316
KOFFIN DRAGGER
kdrodworks316's Avatar
I have a trac bar kit in the R&D stages, I will post it and add it to my site once its ready for production.
If the life I live dont kill me, then I guess I'll never die!
New updated stuff at www.kdrodworks.com
My site still needs help, web guys and gals pm me.
the best guys in the whole world:
sweet70beast, jonzcustomshop, runninlow, captainfab, and the one I havent met yet, joe231
kdrodworks316 is offline   Reply With Quote
Old 11-16-2008, 12:32 AM   #12
project 67 sub
project 67 sub's Avatar
my burb is lowered 5" in the rear and just bent mine for now and it works fine
project 67 sub is offline   Reply With Quote
