Old 11-13-2008, 09:09 PM   #1
camaney
how to put power stering on a 67 gmc
ok i have 67 gmc shorth bed, also a 70 chevy shorth bed my chevy has power stering my gmc does not i notice the frame where the stering gear is has a indent for the chevy, the gmc does not how do i make it to fit and what years should i look for? thanks
camaney is offline   Reply With Quote
Old 11-14-2008, 10:55 AM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: how to put power stering on a 67 gmc
Howdy... I have a 68 and I just used some washers to make up for the lack of indent on the frame. However, if you do a search under this forum, you will find some good info.
I believe mine came out of a late 70's or early 80's truck.
As for the indent, some guys have just banged the frame with a big hammer, others have cut, some use a torch to create the indent. I saw one that had an adapter for a 66 chevrolet. Not sure where he got that but it looks well made.
Here's a bump for you in case someone has more ideas...
68gmsee is offline   Reply With Quote
Old 11-14-2008, 11:34 AM   #3
jorgensensc
jorgensensc's Avatar
Careful using washers to space it out. It actually throws off the steering column line and can cause gearbox bearing wear, etc. Just a little heads up. If it were me I would heat and hammer the indention in. That seems the best way in my opinion.
Shawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 11-14-2008, 06:31 PM   #4
68gmsee
Active Member
68gmsee's Avatar
True, true... In my case, my 68 has somewhat of an indent, just not enough. So a couple of washers was all I needed.
The bracket that I saw someone use on a 66 will certainly bring it out more at an angle. I believe if it was extreme, I would use some sort of swivel connector on the steering shaft like the hotrodders do.
Otherwise, I agree that creating your own indentation is the route to go.
Old 12-13-2008, 01:46 AM   #5
68 C-10 KID
Mean Green
68 C-10 KID's Avatar
a place called dans classics sells the kit to convert it. very chep
68 C-10 KID is offline   Reply With Quote
Old 12-13-2008, 11:22 AM   #6
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Just the FAQs for you
http://67-72chevytrucks.com/vboard/s...d.php?t=216886
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
