Old 11-13-2008, 11:07 PM   #1
vern350
like a rock
vern350's Avatar
17x11
Anyone run 17x11 in the rear of their trucks or know of a rim that will work
vern350 is offline   Reply With Quote
Old 11-14-2008, 11:14 AM   #2
Cherub
Cherub's Avatar
Re: 17x11
Anything is possible but I think it will depend on the drop and the backspacing. My 17X10s are pretty close.
Cherub is offline   Reply With Quote
Old 11-14-2008, 02:47 PM   #3
vern350
like a rock
vern350's Avatar
Re: 17x11
have you got pictures of your setup Cherub?
Old 11-14-2008, 02:50 PM   #4
Cherub
Cherub's Avatar
Re: 17x11
I have pics but it they arent a good angle. ill take some tonight and try and measure the back spacing.
Old 11-15-2008, 02:03 AM   #5
Slammed '87
Slammed '87's Avatar
Re: 17x11
I run 17 by 11's on all my trucks. I like them because they are wide and you can also tuck em easily on these trucks with the right custom backspacing. Check out my piks...I ain't posting all the info on all the rims/and backspacing because they are all different, by if you have specific questions feel free to ask and i'll answer.
If you can't rock the roads with your bumpers 1/2" off the ground, you're nowhere near low enough!
Slammed '87 is offline   Reply With Quote
Old 11-15-2008, 11:58 AM   #6
vern350
like a rock
vern350's Avatar
Re: 17x11
Looking real good Slammed '87, currious to the tires specs and rim offset on that black/grey truck if you don't mind.
Old 11-15-2008, 12:40 PM   #7
Slammed '87
Re: 17x11
In the first two pictures the rears are 17 by 11 with 3.5" backspacing and 335/35/17 rubber. They stick out a little more than i'd like but i bought them used. They came off a truck with a Ford 9" rearend. I plan to do the same someday. In the third pic the rears are 17 by 11 with 5" backspacing and 315/35/17 rubber. The best backspacing i have found on a 17 by 11 if you want to be real low is 5.5".
Old 11-15-2008, 12:46 PM   #8
vern350
like a rock
vern350's Avatar
Re: 17x11
I think I'm pointed in the right direction now. What drop do you have on the truck in the 1st/2nd pictures?
Old 11-15-2008, 12:58 PM   #9
Slammed '87
Re: 17x11
In those pictures it's about 6/5" drop. The front is 6" with 3" spindles and 3" springs. The rear is approx 8 - 9" with flip kit, two removed leaf springs and air bags. In those pictures the rear is aired up so the tires don't rub. I would guess it's sitting at about 5" lower then stock.
Old 11-15-2008, 01:06 PM   #10
vern350
like a rock
vern350's Avatar
Re: 17x11
thanks, this has helped alot.....
Old 11-15-2008, 01:08 PM   #11
Slammed '87
Re: 17x11
no prob. I look forward to seeing it lowered and what rims you pick.
