accepting donations
Transmission question
Im looking at a 72 short bed with a 350/350
The guy said the tranny is set up for racing and will only shift manually and does not go into reverse Any idea what would have to be done to fix it?
1999 Yamaha roadstar 1600 chop. (in progress.) See my builds here>http://s113.photobucket.com/albums/n238/nickrp_2006/ "Ya'll can go to hell, I'm going to Texas." David Crockett |
Re: Transmission question
I have a fully built th350 to hold over 1000hp and it goes in reverse perfectly I dont know how they built that one. A manual valve body for the shifting is fine,but you should be able to have reverse with no issues..
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
i dont know much about transmissions but an autotrans that you can only shift manualy and doesnt have reverse, sounds to me like the guy is covering for the fact that the tranny is bad
i hang around quite a few racers both drag and track and there a a couple who have built up th350's and one powerglide and none of those trannys have any issues shifting or with reverse i would have a tranny shop check out that tranny with you and the current owner present so the story is straight
Trial and Error, its expensive but its a mistake i most likely wont make again 1971 chevy k10 custom deluxe http://67-72chevytrucks.com/vboard/s...d.php?t=341257 1968 chevy k/10 fleet http://67-72chevytrucks.com/vboard/s...d.php?t=334731 1948 desoto custom coupe fluid drive(family heirloom) |
#4 | |
accepting donations
Wonder if there is a pressure plate mixed up or something.
