11-14-2008, 11:27 PM | #1 |
Help With Carb Linkage 70-GMC
I am hoping that one of you out there have experienced this issue and can help me find a solution.
I just completed a V8 Conversion from a V6 on my 70 GMC Short Box.. I am having an issue converting the throttle lever or finding a kit of some sort. Any Ideas? Thanks ALL
1970 GMC 1500 Super Custom 1970 Olds 442 Convertible 1968 GMC 1500 Super Custom 2007 Honda ST1300 |
11-15-2008, 01:35 AM | #2 |
GM ONLY BABY!!!
Re: Help With Carb Linkage 70-GMC
Does www.lmctruck.com show any pics of the v6 and v8 stuff? My 72 GMC has a throttle cable in black plastic housing. What type of throttle linkage was on the v6? Maybe update it to the newer style throttle cable.
2 wrongs don't make a right, but 3 lefts do. 66 Chevelle Malibu 406ci, 573hp, 10.99@121mph 96 Chevy Silverado Z71 72 GMC 1500 Super Custom LS 6.0/4L65 on airride http://www.cardomain.com/ride/707879...mc-c-k-pick-up |
11-15-2008, 07:03 AM | #3 |
Gone to greener pastures
If it's a rod linkage, maybe this will help.
On my truck, the PO just cut a chunk out of the middle of the linkage rod & then welded it back together. It's been working fine for ages. Probably a 10 minute job, if that.
'69 Chevy 1/2 T LWB Stepper: Daily Beater '72 GMC 3/4 T Fleet: Another Daily Beater '72 Plymouth Gran Coupe: ? "Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche "Never kick a fresh turd on a hot day." Harry S. Truman GUN CONTROL: Never having to say, "I missed you." Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck |
11-15-2008, 03:55 PM | #4 |
GM ONLY BABY!!!
Or try some threaded rod. My 66 Chevelle had a fine thread 1/4" rod. It's not 1/4-20 because that is course thread. So, it might be 1/4-24 or 1/4-28 whatever the fine thread may be.
11-16-2008, 02:20 AM | #5 |
Thanks for all of your suggestions..
11-16-2008, 11:32 AM | #6 |
It depends on what carb you have. I have an edelbrock with the 1/2" hole at the top of the linkage. Jegs carries the adapter. http://www.jegs.com/i/Mr.+Gasket/720/1512/10002/-1
I got the HELP brand cable stop assortment, picked the largest one and drilled out the hole for the cable to the diameter of the original rod. I think I ran a tap the rest of the way through. Then stacked washers to fit through the half inch hole. |
11-16-2008, 12:56 PM | #7 |
its all about the +6 inches
do you have a photo of the actual problem?
11-16-2008, 11:30 PM | #8 |
GM ONLY BABY!!!
I just noticed today that these people have a throttle linkage for 6cyl. or v8's.
http://www.classicparts.com/Engine-P...ducts/311/13/0 And I still have my old throttle rod that was used on my old v8 with the Qjet carb. I switched over to a Holley.
2 wrongs don't make a right, but 3 lefts do. 66 Chevelle Malibu 406ci, 573hp, 10.99@121mph 96 Chevy Silverado Z71 72 GMC 1500 Super Custom LS 6.0/4L65 on airride http://www.cardomain.com/ride/707879...mc-c-k-pick-up Last edited by chevydog66; 11-16-2008 at 11:31 PM. |
