Old 11-14-2008, 11:44 PM   #1
smoked68
smoked68's Avatar
Power steering for 68 C-10 SWB???
Ok heres the deal, I have not been here in a while. Bought another Busa and have been playing with it so... It is now time to put power steering in the chevy. What parts will I need and from what year trucks will work? I would appreciate the input. Have a good day and thank you. Mike
1968 chevy shortbed, Dark Shadow Gray
4 bolt 383 Stroker,Weiand Super Charger, disc brakes, 9 inch, 391 gear, 20" Eagle wheels, muncie 4 speed/ Hurst shifter, 4/7 drop, Hedman midlengths, 3 inch exhaust w/ 2 chamber flows. 1966 Mustang with 306 roller, c-4, 9 inch Detroit locker rear. 1965 Fastback Mustang w/347 stroker, top loader 4spd, 9 inch detroit locker. 1966 Mustang coup, 306 roller, c4, 9 inch. 65 Cobra, 427, T6oo, 9inch, of course. First gen Hayabusa, airbox mod and running 2 exhaust cams.. Zoom Zoom Zoom
smoked68 is offline   Reply With Quote
Old 11-15-2008, 01:12 AM   #2
prostreetC-10
My Carbon Footprint
prostreetC-10's Avatar
Re: Power steering for 68 C-10 SWB???
I think you will only need a power steering pump, correct brackets for either short or long water pump, lines and a power steering gear box. I took out the power steering unit from a '68 3/4 ton and it fell right in....worked perfect. If it's a long pump, you can still get the engine brackets from the chebby dealer. Here are a couple of pics as I was mocking-up the engine compartment. Unfortunately, I don't know the year spreads that will work but I think you should go after the 3/4 ton stuff because that seems to be what is parted out the most for the least $$$.
prostreetC-10 is offline   Reply With Quote
Old 11-15-2008, 02:58 PM   #3
smoked68
smoked68's Avatar
Anyone Else???Good info fromProstreet C*-10, but anyone else know anything...
Old 11-15-2008, 05:03 PM   #4
msgross
msgross's Avatar
Some 68's have flat frames in the steering box area so you will need to dent or "dimple" the frame or pick up an adapter made for a 60-66 conversion and bolt it on. This will space the box away from the frame for it to mount.
Other than that I believe any chevy 2WD system will bolt up for you. The power steering pulley alignment is causing me trouble right now. I need to add a 3-groove crank pulley and find the right PS pump pulley for a short water pump...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
