Old 11-15-2008, 12:24 AM   #1
BarryB
BarryB's Avatar
Aluminum driveshafts, are any of you guys running one?
See heres the deal, i took a one piece aluminum driveshaft from a long bed S10. I am curious to find out if it will work or not. I am not concerned weather or not I need to have it shortened. Thats not a big deal, since I have a shop close by that can do it if need be. Just shooting up in the air and see where this leads me.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box.
* You may be only one person in the world, But you may also be the world to one person.
* Some mistakes are too much fun to only make once.
Two rules in life.
1. Never sweat the small stuff!
2. Everything is small stuff!
BarryB is offline   Reply With Quote
Old 11-15-2008, 12:42 AM   #2
smoked68
smoked68's Avatar
Re: Aluminum driveshafts, are any of you guys running one?
I have a 1 pc in my 68, works fine with no problems. My son has an aluminum drv shaft in his 97 Cobra. Car has a 125 shot of nos on it and he has not twisted the shaft, so I'd say it'll work.
1968 chevy shortbed, Dark Shadow Gray
4 bolt 383 Stroker,Weiand Super Charger, disc brakes, 9 inch, 391 gear, 20" Eagle wheels, muncie 4 speed/ Hurst shifter, 4/7 drop, Hedman midlengths, 3 inch exhaust w/ 2 chamber flows. 1966 Mustang with 306 roller, c-4, 9 inch Detroit locker rear. 1965 Fastback Mustang w/347 stroker, top loader 4spd, 9 inch detroit locker. 1966 Mustang coup, 306 roller, c4, 9 inch. 65 Cobra, 427, T6oo, 9inch, of course. First gen Hayabusa, airbox mod and running 2 exhaust cams.. Zoom Zoom Zoom
smoked68 is offline   Reply With Quote
Old 11-15-2008, 10:26 AM   #3
69trk
69trk's Avatar
Mine is a 3" aluminum shaft and seams to be holding up really well. I'm planning on hooking up nitrous to mine sometime next year.
http://67-72chevytrucks.com/vboard/s...d.php?t=494388
431 big block times, changed to a 6.0 ls with turbo
1.58- 60'
7.18- 1/8th mile@95.18
11.37- 1/4 @115.81
69trk is offline   Reply With Quote
Old 11-15-2008, 01:13 PM   #4
dfosh
A friend put one in 48 ford coupe with a 351 engine works fine . It came out of a ford ranger . It bolted right in . Anyone that has used them in our trucks could you give info . Like what it came out of and did you have to modify ?
dfosh is offline   Reply With Quote
Old 11-15-2008, 02:03 PM   #5
petey-pablo
"THE GREEN GOBLIN"
petey-pablo's Avatar
X2 I'd Like to know too.........
Petey-pablo
"THE GREEN GOBLIN"
1972 Cheyenne 10 Short Fleet Side
Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs.
454BBC TH400,Posi
1971 Cheyenne 10 Long Fleet Side
454BBC TH350,Posi Sold
Drive it like you stole it!
Petey-pablo@sbcglobal.net
petey-pablo is offline   Reply With Quote
Old 11-15-2008, 03:27 PM   #6
BarryB
BarryB's Avatar
The biggest reason, Is I am unsure if maybe if they were ballanced different fro the newer trans. It has some kind of balancer on the yoke that goes to the trans. I'm sure I could just try and see how it goes but my truck is a long way from being ready for a driveshaft.
Two rules in life.
Old 11-15-2008, 09:33 PM   #7
hugger6933
The balancer on the yoke is probably for a 5 speed transmission. The General used them to help with gear noise and vibration. Jim
hugger6933 is offline   Reply With Quote
Old 11-15-2008, 10:10 PM   #8
nuke1
nuke1's Avatar
i run an aluminum driveshaft in my truck
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 11-16-2008, 12:45 AM   #9
71stub
71stub's Avatar
A friend of mine just put an aluminum driveshaft out of a 95 or so caprice cop car in his shortbox 72 that has a 700r4 trans in it. He said it was the right length and bolted right in but it was in a pile of driveshafts so they are unsure of what it came out of but that cop car was what they guessed to to be anyways. Hope this helps. Maybe somebody could crawl under a cop car down at the station and get a length for us?
1971 Cheyenne Short Fleet - 468BB/TH400, Tilt, Tach, PS, PB
1967 Custom Short Fleet - 327/4spd
71stub is offline   Reply With Quote
Old 11-16-2008, 03:11 AM   #10
BarryB
BarryB's Avatar
The truck i removed it from had an automatic. No matter, I bet your correct about keeping the vibratioons down, because it also has a plastic sleeve almost the whole length of the shaft. I am assuming it it some kind of noise damper.
Two rules in life.
Old 11-25-2008, 11:53 AM   #11
71stub
71stub's Avatar
I talked to my friend about his aluminum driveshaft he is running. He got it out of a 92-98or so crown victoria. (I call em the bubble top fords) They use a 354 u-joint and our trucks use a 369 so he installed a 353 u-joint which has bastard ends on it and it works perfect. He is running a 700R4 in a shortbox. Hope this helps.
