Old 11-15-2008, 05:41 PM   #1
BP68
BP68's Avatar
Magnaflow Exhaust kit
Finlly got my exhaust hooked up for now.
A little info for anyone thinking about using the stainless Magnaflow kit for our trucks - If you use a 4/6 drop the rear taillpipes will not work. If you use shorty headders and a 700R4 the pipes from the headders to the x pipe will not work.
I ended up having the muffler shop bend up the tubes from the headders to the x pipe and I will use turn downs either before the axle or after.
For my application, if I did it over again, I would prob just order the mufflers only and have regular pipe run at the muffler shop.
I will try to post some pics once I get it back on the lift.
68 C10 Shortbed Fleetside
06 Chevy Ext Cab Fleetside
03 Grand Prix GTP
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=269999
BP68 is offline   Reply With Quote
Old 11-15-2008, 08:06 PM   #2
Ackattack
Ackattack's Avatar
Re: Magnaflow Exhaust kit
I used the Pypes brand kit (stainless w/ X-pipe also). I had to do a lot of hacking and welding to get it all to fit up. The X-pipe really makes things difficult.
Oh, mine dumps in front of the axle too.
Ackattack is offline   Reply With Quote
Old 11-17-2008, 09:32 AM   #3
68Stepbed
68Stepbed's Avatar
I always wondered how well that kit worked with lowered suspensions. I had never seen one installed on anything but stock or slightly lowered trucks.
Thanks for posting that info.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 11-17-2008, 04:39 PM   #4
70rs/ss
70rs/ss's Avatar
They work for the applications they are intended for, any deviation thereof and you are now into "custom" aka make it yourself territory! I want to use that kit (magna flow) since the price seemed right, but I too am lowering it, so I may just get the box of pipes kit and make it work, since reverse engineering a kit made to fit something else??
70rs/ss is offline   Reply With Quote
