Old 11-15-2008, 10:41 PM   #1
arkracing
Weekend Warrior
Smile WIW? - '78 Crew Cab: Pics Inside
So my friend bought a '78 crew cab & has now decided that because it needs a little work, he doesn't want to be bothered with it anymore. So he sold the 454/TH400 out of it. It has 78k on the clock and he bought it from the original owner - who gave him all the paperwork on the truck, including the original sales reciept. Interior is in decent shape, the seats are clean with no rips, the dash has several cracks in it though.
it is in fairly decent shape, but does need some work. The area of most concern to me is the upper door jamb on the drivers side rear. It has started to rot (not sure if water is getting into the roof cavity, or if there were leaves/dirt stuck up there). There is a little bit of rot on the driver's side inner rocker/cab support that the Original Owner "fixed" with expandable foam. There is also some rot on the lower rear bedsides right behind the tire, but the wheel arches are perfect & the bed floor is perfect - so that is a HUGE plus in the body work department. I HATE rotted wheel arches, seems you can never get them to look "factory" again.
I kinda like the early crew cabs, and it is a nice truck, drives and rides super nice & quite. I would just put a small block back in it & I have another TH400 in stock.
I don't need any more projects, but I hate to see it get parted out and the rest get crushed.
I think I can get it for less than $500 WITHOUT the wheels & tires. Is it worth it or? I know that I would like to have the 14bolt FF rear axle with 3.73gears to go with a D60 Front that I have - eventually want to have them in a '67-'72 Pickup. I guess I just hate to see a decent truck go.
-'07 GMC Sierra K2500HD
-'66 C10 Suburban
-'68/'71 K20 Service Bed Project
-'69 Chevy C30 Mason Dump
-'33Ford P/U 396ChevyPowered
arkracing is offline   Reply With Quote
Old 11-16-2008, 12:01 AM   #2
joe231
joe231's Avatar
Re: WIW? - '78 Crew Cab: Pics Inside
i'd jump on it, but i want to build a 1/2 ton crew cab short bed some kinda bad
CHEVY ONLY
Old 11-16-2008, 01:08 AM   #3
streetstar
streetstar's Avatar
that cab looks pretty gruesome, but since it is a specialty truck, may be worth fixing -- but thats up to you
If it was a regular cab truck -- some of that rust would make me run the other way
Are you retired too?
Nonsense! I'm in my prime
streetstar is offline   Reply With Quote
Old 11-16-2008, 08:02 AM   #4
grinch4om
dang its hot
grinch4om's Avatar
me personnally? if you need the rear, it's worth 300 otherwise, you'd need to love it to tackle it
grinch4om is offline   Reply With Quote
Old 11-16-2008, 10:07 AM   #5
arkracing
Weekend Warrior
I don't need the rear - but it sure would be nice to have as I have a Front
D60 (for some use in the future). And I like the fact that the rear has 3.73 gears - good all around 4x4 gear. So I would just have to put a set of gears in the 60 and have a good set of 1ton 4x4 axles.
I think I can get the whole truck for $300. And I could just part out the rest - the front fenders and all the doors are still good on the truck.
-'66 C10 Suburban
Old 11-16-2008, 01:30 PM   #6
ed3196499
ed3196499's Avatar
If you get it and decide to part it out I am interested in the headliner and some interior trim parts
Ed
U.S. Coast Guard BMC (retired)
ed3196499 is offline   Reply With Quote
Old 11-16-2008, 09:08 PM   #7
Pyrotechnic
Pyrotechnic's Avatar
Maybe just do a very cheap paint job to make it one color and use it for a work truck or tow vehicle ? Would be handy for things you don't wanna do with your nice truck. Just build it up over time with spare parts you already have or you found for a bargain to keep cost down.
1977 GMC Sierra Grande
Pyrotechnic is offline   Reply With Quote
Old 11-16-2008, 10:00 PM   #8
Blazer Eagle
i do it, those dont come around often, a little rust, but like pyrotechnic said, just por15 it and fix when you get around to it, when those are done right though, those are some sharp looking trucks
Blazer Eagle is offline   Reply With Quote
Old 11-16-2008, 10:26 PM   #9
toomanytoyz
Luv the Crewcabs
toomanytoyz's Avatar
What are you waiting for, That is a Steal at that Price.........
Rick
55 Nomad
52 Willys Truck
67 Stepper
67 Fleet
68 Wrecker
68 Suburban
76 Crewcab
79 Gmc Dumptruck
84 Blazer
86 Crewcab Stepside
87 Iroc
89 GMC Plow Truck
91 Camaro Vert
96 Z71 Stepsde
toomanytoyz is offline   Reply With Quote
