Old 11-15-2008, 10:47 PM   #1
leos11104
leos11104's Avatar
ls swap
hello just wantin to know what vehical years i can get the 5.3 and the 6.0 from thanks
leos11104 is offline   Reply With Quote
Old 11-16-2008, 12:17 AM   #2
kylepatrick03
Re: ls swap
I'm not an expert on them, but I have a 2004 in the garage, and have been researching the swap, they started using them in 1999, but there are different versions them in the newer years, ie flex fuel, active cylinder management etc. And the Painless Wiring Kits for the fuel injection system go through 2004. The carb setup from MSD/Edelbrock may work on some of the newers ones. Also, if you go EFI you will need to get the computer repogrammed as well.
Kyle
kylepatrick03 is offline   Reply With Quote
Old 11-16-2008, 10:06 AM   #3
hugger6933
Re: ls swap
If you are going with a 6.0 stay away from the 99 model. It had cast iron heads that didn't perform quite as well, plus they add uneeded weight. Also the crank flange spacing is different. Jim
hugger6933 is offline   Reply With Quote
Old 11-16-2008, 10:47 AM   #4
HillClimber
HillClimber's Avatar
Re: ls swap
all the reading i have done says to stay 03 or before, after that the changed to drive by wire, which is not horrible but you then have to mount a gas pedal from the newer model truck as well to get the electric signal to cpu. I am looking at doing a 6.0l swap myself
HillClimber is offline   Reply With Quote
Old 11-16-2008, 01:59 PM   #5
Ackattack
Ackattack's Avatar
Re: ls swap
I'm using drive by wire. The benefit of it is it's easy to add cruise control....basically run a few wires from cruise control turn signal lever.
Ackattack is offline   Reply With Quote
Old 11-16-2008, 02:09 PM   #6
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Re: ls swap
You can always go with a carb and a front mount dizzy...or use a carb and a GM, FAST, MSD or other LS controller for the spark.
How about one of the new LSX sportsman block based LSX's coming out soon?
LSX376 — Available Soon
GM Performance Parts takes the LSX Bowtie block and combines it with the LS3’s L92-style heads to create the LSX376 crate engine. This engine will be delivered without an intake manifold (and other accessories), but can be fitted with either a carburetor or production-style injection system to make it suitable for your street rod, ’57 Chevy or ’71 Camaro....or '67-'72 truck!
Specifications:
Part Number: 19171049 Cylinder Heads (P/N 12615879): Aluminum L92 style port; “as cast”
Engine Type: LSX Series Gen IV small-block V-8 with 68cc chambers
Displacement (cu in): 376 (6.2L) Valve Size (in): 2.16 intake / 1.59 exhaust
Bore x Stroke (in): 4.06 x 3.62 (103.25 x 92 mm) Compression ratio: 10.7:1
Block (P/N 19243171): LSX cast-iron with 6-bolt Rocker Arms (P/N 12569167 int): Investment-cast, roll trunnion
cross-bolted main caps Rocker Arms (P/N 10214664 exh): Investment-cast, roll trunnion
Crankshaft (P/N 12597569): Nodular iron Rocker Arm Ratio: 1.7:1
Connecting Rods (P/N 12607475): Powdered metal Recommended Fuel: 92 octane
Pistons (P/N 12166957): Forged aluminum Maximum Recommended RPM: 6600
Camshaft Type (P/N 12603844): Hydraulic roller Reluctor Wheel: 58X
Valve Lift (in): 0.551" intake / 0.522" exhaust Balanced: Internal
Camshaft Duration (@0.050 in): 204° intake / 211° exhaust
LSX454 — Available Soon
An engine with 454 cid will always recall legendary Chevys, and that tradition will continue with the all-new LSX454 crate engine. Based on the LSX Bowtie block, the new LSX454 will be delivered in Deluxe form, so you’ll get everything you need from the carburetor to the water pump, plus “LSX454” engraved valve cover logos.
Specifications:
Part Number: 19170112 Cylinder Heads (P/N 19201806): Aluminum LSX-LS7 port;
Engine Type: LSX Series Gen IV small-block V-8 "as cast" with 70cc chambers
Displacement (cu in): 454 (7.4L) Valve Size (in): 2.20 intake / 1.61 exhaust
Bore x Stroke (in): 4.185 x 4.125 (106.3 x 104.8 mm) Compression ratio: 11.0:1
Block (P/N 19243172): LSX cast-iron with 6-bolt Rocker Arms (P/N 12579615 int): Investment-cast, roll trunnion
cross-bolted main caps Rocker Arms (P/N 12579617 exh): Investment-cast, roll trunnion
Crankshaft (P/N 19170391): 4340 forged steel Rocker Arm Ratio: 1.8:1
Connecting Rods (P/N 19166964): 4340 forged steel Recommended Fuel: 92 octane
Pistons (P/N 19166958): Forged aluminum Maximum Recommended RPM: 6500
Camshaft Type (P/N 19166972): Hydraulic roller Reluctor Wheel: 58X
Valve Lift (in): 0.635" intake / 0.635” exhaust Balanced: Internal
Camshaft Duration (@0.050 in): 236° intake / 246° exhaust
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 11-17-2008, 08:55 PM   #7
Ford Assassin
Ford Assassin's Avatar
Re: ls swap
I am nearly finished with my 2004 5.3 swap. The DBW is easy, just make sure you grab the pedal and control box from the donor.
It also looks cleaner IMO, no throttle cable on the firewall.
Cable
-K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt
-Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608
Ford Assassin is offline   Reply With Quote
Old 11-17-2008, 11:30 PM   #8
drman929
drman929's Avatar
Re: ls swap
I agree with ford assassin. It was easier to install the DBW unit than to mess with the cable. It's also really easy to floor it....hehe
drman929 is offline   Reply With Quote
Old 11-17-2008, 11:38 PM   #9
HillClimber
Re: ls swap
i might have to go that route myself then. makes it easier to find an engine as well then
Old 11-19-2008, 12:05 PM   #10
leos11104
leos11104's Avatar
Re: ls swap
how difficult is this swap
Old 11-19-2008, 03:10 PM   #11
Hart_Rod
Hart_Rod's Avatar
Re: ls swap
That's a loaded question..........................
Hart_Rod is offline   Reply With Quote
