Old 11-15-2008, 11:54 PM   #1
joe231
joe231's Avatar
Power door conversion question
I have another question about converting to power. I'm going to get a pair of power doors off of a '85 tomorrow to convert my '80.
I realize I can just use the guts but my doors on my '80 have rust and someone repaired them by welding by the hinges and the door now lacks the adjustment needed to align properly with the fender and hood.
so my main question is about the wiring. does it unplug inside the cab somewhere, or do I need to cut wires? how many wires run to the drivers door, and how many run from the drivers to the passengers?
anyone have a schematic?
I would prefer not to stumble in blindly.
oh and also, do i have to pull the fenders to pull the doors?
Thanks for all the help, it is mucho appreciated.
CHEVY ONLY
Old 11-16-2008, 04:57 AM   #2
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
Re: Power door conversion question
so my main question is about the wiring. does it unplug inside the cab somewhere, or do I need to cut wires? Yes it does. And you will need the harness that plugs into the harness and runs from side to side as well as the 30amp circuit breaker in the fuse block for the power windows and the power door lock relay that should be mounted to the top of the accelerator bracket. There are 2 power leads that pluginto the fuse panel and 2 ground leads that plug onto the 6-way ground plug behind the cluster on the left. Make sure when you install it into your truk that you properly mount the P/L relay otherwise they won't workhow many wires run to the drivers door, and how many run from the drivers to the passengers?
oh and also, do i have to pull the fenders to pull the doors?No you can simply unbolt the doors from the hinges. HOWEVER; In order to drill out the proper size holes in the proper locations on either side of the cab, it's best to loosen if not remove the fenders to get into it better. When I cut my suburban for power windows/locks/mirrors I didn't and I messed up the holes with the hole saw(egg shaped not round and had to glob in some silicone sealant around it.
Good Luck and have fun!!
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 11-16-2008, 06:19 AM   #3
73chevyman
73chevyman's Avatar
Hey Joe send me some feed back cause I want to do the same thing with my 73 I'm lazy and rather push a button then lean over hahaha..
http://67-72chevytrucks.com/vboard/group.php?groupid=37
73 C10 Fleetside
If it ain't a Chevy it's foreign
http://hotridesmag.com/
73chevyman is offline   Reply With Quote
Old 11-16-2008, 07:42 AM   #4
Mr79C10
It Is What It Is,,,,
Mr79C10's Avatar
Hey Joe,,
When you do this, if ya could try to post a few pics. Im going to do the same thing to my 79
BLE 'BURBAN,
Great reply and very helpful, Thanks
*79 C10 Short Box ST8 6 bang'r *
*Lowered w/ 3" Control arms, 2" Lower Coils and 4" shackles and hangers W/ FLIP KIT
*__--__*
79 C-10 project
.........................__
..............._____ l __\___
..............|_(O)_ |___(O) ]
FAQ INDEX Thread
The Kulture
My Rat Den
Mr79C10 is offline   Reply With Quote
Old 11-16-2008, 10:48 AM   #5
joe231
joe231's Avatar
Cool!
Thanks for the info!!
Originally Posted by Mr79C10 View Post
Hey Joe,,
BLE 'BURBAN,
will do!
CHEVY ONLY
Old 11-17-2008, 04:48 PM   #6
joe231
joe231's Avatar
BLE 'BURBAN, your info was very helpful!
I got the doors, the passenger side is junk and missing parts, including the power window motor, so I will probably look for another or just use my shell. Driver's door is complete minus the double power window switch. I got the complete power door harness, including that little PIA lock relay
I will get some pics on here of the pieces and parts and start another thread when i do the change over. should be relatively simple and straight forward, I've heard that one before
Thanks again for the info
CHEVY ONLY
Old 11-23-2008, 05:19 AM   #7
BLE 'BURBAN
Anytime dude. I do what I can when I can to help out.
After all, what goes around, comes around.
Old 11-23-2008, 08:19 AM   #8
Mr79C10
Mr79C10's Avatar
So true....!
*__--__*
79 C-10 project
FAQ INDEX Thread
The Kulture
My Rat Den
Old 11-24-2008, 09:00 PM   #9
mainermikeyd
mainermikeyd's Avatar
Pics Joe would be great, I am actually trying the same thing with a 82 sierra to 86 sierra full power options!!!!! Start mine thurs I'll letya know my progress bud!!!!
Once a Marine Always a Marine OOH-RAH
GM Fanatic
1982 K20 4" Rancho lift 350cid, edelbrock performer intake 1405 carb, hedman headers, TH350, " Wheres the MUD!!!!!!!!!!"
1986 c30 camper special 454, th400 (for sale)
1984 K10 Big Ten (project) needs motor
1984 C10 355, 700r4, (project) needs shortbox bed
mainermikeyd is offline   Reply With Quote
Old 12-09-2008, 09:25 PM   #10
Mr79C10
Mr79C10's Avatar
well, any pics yet?
*__--__*
79 C-10 project
FAQ INDEX Thread
The Kulture
My Rat Den
Old 12-09-2008, 09:35 PM   #11
joe231
joe231's Avatar
I can take pics of the parts sitting in my garage if ya like. i need a passenger door still, so I haven't started swapping yet
CHEVY ONLY
Old 12-09-2008, 09:50 PM   #12
suicide 63
whats taking so long ,oh by the just have to do this
suicide 63 is offline   Reply With Quote
Old 12-09-2008, 09:54 PM   #13
joe231
joe231's Avatar
damn-it!
busted....would you like to be a deputy
CHEVY ONLY
Old 12-09-2008, 10:15 PM   #14
joe231
joe231's Avatar
CHEVY ONLY
Old 12-09-2008, 10:19 PM   #15
joe231
joe231's Avatar
while I was there getting the doors, i grabbed this....
not sure what it is.
is it for the ESC or is it a DRAC?
'85 half ton, anyone need it?
CHEVY ONLY
Old 12-11-2008, 03:16 PM   #16
joe231
joe231's Avatar
anyone?
CHEVY ONLY
Old 12-15-2008, 04:04 AM   #17
BLE 'BURBAN
That there part is the cruise control module.
Old 12-15-2008, 09:22 AM   #18
joe231
joe231's Avatar
cool, thanks
CHEVY ONLY
Old 01-13-2009, 05:45 AM   #19
1987 Shortwide
This makes a little more sense now. Good thing you asked the question on the door wiring, because I now get to go dig around a salvage yard for the center harnes and circuit breaker.
~Steve~
Friesen High Performance Auto and Graphics
Toy: 87 Shortwide, 406 smallblock with a little boost
My 87 buildup
Daily Driver: 99 Sierra SLE 4X4. Black on Black and harder than hell to keep clean.
1987 Shortwide is offline   Reply With Quote
Old 02-25-2009, 03:22 PM   #20
locab36
locab36's Avatar
I'm doing the power door conversion right now. I drilled the holes in my non-power doors/cab today. Doors are off, fenders are on. The dimples from the factory sure help out. Here are some pics.
John
Locab36
1936 low cab 1/2 ton
1956 BMW R25/3
1968 Moto Guzzi V7
1969 BMW R100/2
1986 Silverado SWB
2007 Harley FLHTP
2011 GMC SWB 4x4 Z71
http://www.flickr.com/photos/locab36...7623329816080/
locab36 is offline   Reply With Quote
Old 02-26-2009, 03:50 AM   #21
factory2wdblazer's
factory2wdblazer's's Avatar
i recently did a power door conversion also. i used the complete door's off a 90 blazer and cut the top's off so the would my 73 blazer. i only have the harrness from the door jam's back...........from what i under stand i need a relay or some thing???? i did not remove the door's off the 90 blazer so i don't know how they where hooked up.....any body know
factory2wdblazer's is offline   Reply With Quote
Old 02-26-2009, 04:09 AM   #22
Twisted78SS
Wide n'Low
Twisted78SS's Avatar
For anyone interested, I have what appears to be a complete power door lock and power window setup I am looking to part with.
I'll put it in the for sale area on Friday once I get some pictures.
(sorry to tread on your thread..)
Trippin Hazard.. 67 swb,
Gold Member.. 68 Suburban
Air Force Retired
Twisted78SS is offline   Reply With Quote
Old 09-25-2009, 08:39 PM   #23
joe231
joe231's Avatar
sorry I missed all this guys
John
Very nice....did you complete it?
I just swapped my '80 to a '73-'74 front end and to my suprise there where dimples where I needed to drill...I was quite happy...takes all the guess work out
did you get this figured out?
did you sell the stuff?
CHEVY ONLY
Old 09-25-2009, 09:07 PM   #24
bigblock73
yeller
bigblock73's Avatar
You can't put factory power windows in your 73...if it still has the original 73 doors. 73-76 doors are different than 77+...they were redesigned in 77 to accomodate PW/PL.
bigblock73 is offline   Reply With Quote
