11-16-2008, 12:54 AM | #1 |
Eaton Rear width ?
Does any one know if I can swap the eaton DRW hubs on to my single rear wheels to get a wider WMS like you can on the 14blt axles ? Stock is 65 and I want to run stock H1 wheels so Im trying to get a wider rear axle with out running wheel spacers.
Earl 68 2500 4x4 GMC Burb |
11-16-2008, 06:28 AM | #2 |
Re: Eaton Rear width ?
I forget at the moment what if any gains you will see doing that, but there is a van width Eaton just like the 14 bolts. I am going from memory, but I believe it is around 70" wide. The only downside is that it uses unique axleshafts, also just like the van 14 bolt.
1969 GMC K2500 1996 Honda Accord 2007 Kawasaki KLR 650 |
