Old 11-16-2008, 01:49 PM   #1
DrtyJack75
HELP - What is the min. size wheel that will fit with disk brakes?
When I ordered my brakes from ECE, I was told that my original wheels would more than likely clear the brake calipers....
BUT...
They dont....so now my truck is on the lift without wheels to fit...
Dont really want to buy wheels right now so I might have to go a the junk yard to get some...
What is the MINIMUM size wheels that will clear the calipers with the ECE Disk brake Kit??
THANKS!!!
DrtyJack75 is offline   Reply With Quote
Old 11-16-2008, 01:52 PM   #2
cdowns
cdowns's Avatar
Re: HELP - What is the min. size wheel that will fit with disk brakes?
what year wheels? pre 71 wheels have a different construction shape that normally wont clear disc brakes
Old 11-16-2008, 02:00 PM   #3
corn
cdowns is correct. Here's the difference that he is talking about...
corn is offline   Reply With Quote
Old 11-16-2008, 02:04 PM   #4
Senator350
Senator350's Avatar
it's pretty routine for guys to grind material from the caliper to fit into 15" wheels...
google search "grinding caliper" and you will see how popular this is on a variety of applications
RN U OVR
Senator350 is offline   Reply With Quote
Old 11-16-2008, 02:26 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
it would take more than some simple grinding.
you need 6 lug wheels offa 71 and up 4X4 truck.
Old 11-16-2008, 03:35 PM   #6
Senator350
Senator350's Avatar
check out how much grinding the ferd lightning dudes do when they want to run a 15" drag wheel...
before and after:
RN U OVR
Old 11-16-2008, 04:09 PM   #7
b-rad
does that make it weak
b-rad is offline   Reply With Quote
Old 11-16-2008, 05:04 PM   #8
DrtyJack75
You guys are good....THANKS!!
Old 11-16-2008, 05:42 PM   #9
DrtyJack75
ok, how bout back spacing? My trucks on a lift and I cant take it to a tire shop to get wheels fit for it....so what back spacing to do I need?
I think Im going with either 20's or 20" in the front and 22" in the back??
20x8 Front and 20 or 22x10 in the rear will fit with no problem right??
thanks again!
