Old 11-16-2008, 09:04 PM   #1
ericpost
ericpost's Avatar
Carb trouble
On steep inclide/declines I need to make sure I stay on the pedal or the truck stalls. I also have to pump the pedal LOTS when the truck sits for more than 3 or more days.
The carb is a Edelbrock 600 which is basically an old Carter AFBstyle. I have run AFB's before and had great luck. I was thinking doing a basic rebuild but don't want to wast my time if edelbrock turned the old AFB into a piece of junk.
Any clues?
72 GMC Jimmy, 350, sm465 np205 (getting a face lift)
64 Nova SS, 327 SC & gassed, TH350. (blowed it up)
84 HD FX frame,80 FL tins, evo with 85hp/90tq (wifes bike)
96 HD FatBoy evo with 102hp/100tq (mine!)
KEEP NOTHING STOCK!
ericpost is offline   Reply With Quote
Old 11-16-2008, 10:52 PM   #2
Mudder
Mudder's Avatar
Re: Carb trouble
Holley makes an off road carb that works really well for steep hill/inclines. I believe that a Quadrajet will be better than what you are running also. Splash is a problem with 4x4's and thats what it sounds like is happening to you.
Mudder is offline   Reply With Quote
Old 11-17-2008, 07:48 AM   #3
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Re: Carb trouble
I was going to suggest a Holley offroad carb for 4x4ing as well. Know a couple kids with them that are very pleased. I had an eldelbrock in my last truck and went and played in the hills with no major issues though. Maybe try a rebuild if you want to go that route. I believe I had the 650 cfm one.
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 11-17-2008, 08:14 AM   #4
Mudder
Mudder's Avatar
Re: Carb trouble
I do think there is a kit you can buy for Holley's. FI helps and thats why a lot of serious off roaders have gone to it.
Old 11-17-2008, 09:09 AM   #5
drbyrdman
drbyrdman's Avatar
Re: Carb trouble
I had the same problem with the edebrock carbs. even put the off road spring kit in and still sucked off roading. would stall and flood. then i got a stage 2 quadajet from jet performance. It worked great!! never had any problems and got even better gas mileage.
drbyrdman is offline   Reply With Quote
Old 11-17-2008, 10:38 PM   #6
dammitmitchell
the pollock
dammitmitchell's Avatar
Re: Carb trouble
ive gots a holley on top of my 350
i floor it.. bounce it, incline, decline.. downshift decline...mud pit romp... never an issue with it.. the only sputtering i get or reduction of power i ever really notice is when i suck water in.. but that's my own fault
Jack of ALL trades, Master of none.. (but one... procrastination)
Army vet 02-08
RIP El Jay! Miss you brother!
http://67-72chevytrucks.com/vboard/s...d.php?t=343538
http://67-72chevytrucks.com/vboard/s...d.php?t=386042
dammitmitchell is offline   Reply With Quote
