It'll buff out
How come my truck just started spinning both tires like a posi?
Me and my friend went out earlier to burn some rubber and gas and it usually just spins one side buti did a burnout and it spun both of them and now it does both of them everytime. It made me happy finally seeing 2 black marks instead of 1.
But i was just wondering why it would start doing that |
Re: How come my truck just started spinning both tires like a posi?
Son,
sit down for a minute. We're going to have a talk about the posi-fairy. HAHAHA dunno. interested in finding out tho!
RN U OVR |
It'll buff out
Haha im not sure i just did a burnout and it started sliding side to side and i looked back and i saw 2 marks, so i just kept doing more cause it made me really happy lol
surprised you stopped long enough to come tell us
![]() your sig line makes a little more sense now!
RN U OVR |
Phone's ringin Dude.
![]() Join Date: Mar 2007
If your trucks anything like mine, random stuff decides to work every now and then. You probably have a posi rear, it just wasn't engaging before.
![]() ![]() 2003 SILVERADO SS--THE NEW GIRL 1972 GMC--THE OLD GIRL |
Old Skool Club
![]() Join Date: Jun 2001
Maybe the non-driven side gave in due to peer pressure from the other side.
Air Lift made a lot of money off of the single-track rear ends by their usage. You could load up the driven side and increase the traction on it, to the point that the other side would grip and give you more equal traction.....without a posi-trac.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
x2
'58 SWB Fleetside...Front & Rear Porterbuilt Dropmember, 6.0 LS /4L60E. Accuair E-level, 20 Billet Specialties (Vintecs) '63 Buick Riviera ... AccuAir E-level, 20" Billet Specialties (Vintecs) http://67-72chevytrucks.com/vboard/s...=528853&page=5 |
ASE master tech/machinist
My 70 short bed used to do the same thing, as well as my 64 short bed. I could turn the wheels and they'd turn in the same direction like a posi. Turns out my buddy that set up the gears put an extra set of shims behind the spiders. But on yours I dunno
![]() Join Date: Jul 2006
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
Enjoying left field
Its possible that after you've roasted one tire for a minute it gets hot and sticky and starts to grip better making the other tire break loose. I've heard of that happening before.
could be a lil moisture on the road or the cool fall air giving a lil more power. i know i took my moms vette down the street and it was more peppy than normal
- Josh Im not white trash, I'm one step above that..... more like white clutter |
![]() Join Date: Dec 2006
The clutches in you posi are pobably burned out. when they get hot enough they will grab, Or your gear oil is really dirty and wont fully let them ingauge. It happened in my old chevelle, I looped it the first time it happened! I would pull the cover and spray out the pumpkin really good with brake kleen, Maybe you can dislodge whatever is in there. You can find out what gears while your at it.
#13 |
BlahBlahBlah
*Note to self..Never buy used parts from allen123*
#14 |
cool ... extra shims and I got a posi!
#15 |
It'll buff out
#16 |
upgrading to an older model
Well one night at the track (dirt track racing), They decided to tech to top 5 finshers...Posi/welded rear-ends are illegal. They jacked up one side gave the wheel a spin and ...NO SPIN. THE REAR-END IS LOCKED. He was shocked...according to him "I can't even weld so how could I have welded it up?" Anyway, long story short, he came back the next week and said that it had been leaking fluid and got too low causing it to over heat and "welded" everything up to "accidentally" make a locked rear-end. Take it for what you want but it could happen...
68 stepside, short-box, multi-colored (for now) ![]() ![]() ![]() |
#17 | |
Remember that the pumpkin is dish shaped.. so when you spray brakleen, be careful it doesn't spray directly back into my face... ummmmm... YOUR face! i meant YOUR face. i would never do something so dumb ![]()
RN U OVR |
#18 |
Enjoying left field
Did that with carb cleaner and a carb once.
#19 |
Restoration Desperation
OK, Cody....it's been 2 days, quite long enough to get out your leatherman & undo the 10 or 12 bolts holding the rear end cover on so you could look inside.
WELL????????? RD |
#20 |
![]() Join Date: Jul 2004
After the spider gears weld themselves to the center pin from doing too many single wheel burnouts, you will have posi for a while, Then the pin starts to spin in the case and eventually parts come out the rear cover. How do I know this ????
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
#21 | |
blood type; Retumbo
a few years ago i was in a contest and mine started making BAD noises after it went posi. it cost a butt-load of cash to fix right. |
#22 |
My Carbon Footprint
your open rearend is so worn out, you spider gears are starting to lock up!
#23 |
The same thing happened to a friends truck years ago. It started to act like a posi so he did a few burnouts then the diff completely disintegrated! It was a 4x4 so he drove it home on the front axle with horrible grinding noises coming from the rear.
1972 K10 Custom Deluxe SWB 350/350/205 AC About to be put back together after sitting in pieces for 23 years. My father (original owner) says "IT'S ABOUT TIME! ![]() |
#24 |
HaHa
![]() What a startling sight I can tell you for a 16 year old! ![]() ![]() chas
"I'll Procrastinate Tomorrow" quote by LEEVON 71 K10 long fleet (sons truck) new 370hp 355, sm465 np205, 3.73's 33's 70 K20 long fleet 98 G3500 work van |
#25 |
It'll buff out
thats kinda scary lol i did another burnout and it was a single
about how much does it cost to fix it |
