Navy Radioman Veteran
TBI swap from '88 to '87
Board member bought an '88 3500 GMC w/454 TBI system. He is going to put it in an older truck and put a carb on it. I'm considering swapping him my factory '76 454 intake / q'jet carb for the TBI w/ecm and put it on my '87.
Will the '87 harness plug into the '88 TB or do I need to jump through hoops to get it done?? Thanks! Ken
1987 Chevrolet R10 Silverado BBC Build thread - SOLD 1986 GMC Sierra Classic - SOLD 1957 Chevy Step Side - At the Body Shop Daily Driver; 2005 Chevrolet Silverado 4x4 Z71 Stepside Last edited by 87Lowrider; 11-17-2008 at 12:28 AM. |
In the Forgotten far North.
![]() Join Date: Jul 2007
Re: TBI swap from '88 to '87
I'd get the full harness off the '88 model under hood and under dash and just swap everything.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015 1990 chevy suburban V2500 5.7L My cluster Mods-Nov 2007 overhead console Stereo install Round 2 Aug 2009 Heated/turn signal mirror upgrade |
#3 | |
Chevys Kick A$$
*HOODS is what I answer too* -'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold ![]() -'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit ![]() ![]() -'86 K5 Blazer Silverado 6.2 4" lift 35"s -'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's -'83 Monte Carlo T-Tops. 126,500 Original Miles -LATER ![]() I would rather push a Chevy then drive a ford!!
I think he has that... we'll see!
Thanks, Kenny
1987 Chevrolet R10 Silverado BBC Build thread - SOLD 1986 GMC Sierra Classic - SOLD 1957 Chevy Step Side - At the Body Shop Daily Driver; 2005 Chevrolet Silverado 4x4 Z71 Stepside |
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
You don't need the harness, you already have one. Just plug it all back up, get his chip and injectors and you are done.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
#6 | |
Thanks Chris! Kenny
Kenny, the factory TBI system may not be able to support your HP level. I think the stock TBI engines are only 260HP or so. Don't you have a healthy cam and some other goodies in your engine?
- Greg |
yea 500hp...didnt consider that
Ken
You may want to check out this site.... http://tbichips.com/
And if you're looking for even more power from a blower setup for a TBI unit check out this one linked thru the one above http://www.tbi-superchargers.com/
The TBI can be setup to handle 450hp with the right components.
did you dyno the truck at 500hp?
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com Last edited by Captkaos; 11-18-2008 at 01:45 AM. |
STILL PLAYS WITH TRUX
If your SBC is pushin 500HP then i seriously doubt you will be happy with the performance output of a stock TBI 454.
#12 | |||
1987 Chevrolet R10 Silverado BBC Build thread - SOLD 1986 GMC Sierra Classic - SOLD 1957 Chevy Step Side - At the Body Shop Daily Driver; 2005 Chevrolet Silverado 4x4 Z71 Stepside Last edited by 87Lowrider; 11-18-2008 at 04:58 PM. |
#13 |
BAD BOW-Silverado XST
Another good tbi website.
http://www.cfm-tech.com/GM_tbi_tuning_tips.htm |
#14 | |
![]() Quote:
Is this swap for fuel savings or other reasons?? |
#15 |
I am sure you have probably posted this, but what are the specs of the motor? Reason I ask is Dyno 2003 has been real generous when I have had a few people play with it.
If you motor isn't setup for less than 5500rpms, and you don't plan to change it, I would move to another TB setup.
#16 | ||
Fuel savings would be the number one reason next to the coolness of having fuel injection on the BBC when I open the hood. Quote:
It is a 1976 Chevrolet 3/4 ton 454 (std bore), Cast Iron Oval Port 781 heads with 2.190 / 1.880 valves with at least a 3 angle job, Comp Cams XE 274h 552/550 lift 286 dur. Comp Cam Full Roller Rockers, MSD Pro Billet Dist, MSD Digital 6 Ignition, MSD HVC Coil, MSD 8.5mm Wires, EdelBrock 1407 750 carb on a Edelbrock Air-Gap Intake. Dyno 2003 shows 488hp / 466ft lbs @ 5500. I have yet to get it up that high yet though, so I don't know if it'll do 5500 or not.
#17 |
That cam range is 1800-6000, you would definitely need a chip burnt for it, and you would have to run the fuel pressure way up to about 25lbs and you would have to mod the TB...
#18 | |
What Would be best, the stock TBI or should I consider something aftermarket?? I know Holley and Edelbrock make 'em. Kenny
1987 Chevrolet R10 Silverado BBC Build thread - SOLD 1986 GMC Sierra Classic - SOLD 1957 Chevy Step Side - At the Body Shop Daily Driver; 2005 Chevrolet Silverado 4x4 Z71 Stepside Last edited by 87Lowrider; 11-19-2008 at 08:42 PM. |
#19 |
How much you have to spend? How easy do you want to tune it? Will you want to play with the ECM?
The only thing that is sorta out of place it the Lobe seperation. ECM's usually like 112, and that cam is 108. I will work though.
#20 |
To me, throttle body injection has a pretty low coolness factor on a performance engine. I would rather see a double pumper carb. Now a nice custom multi-port injection setup... that would be the ultimate coolness.
![]() But if TBI is what you want, look into just getting an adapter plate that lets you mount the TBI unit onto your existing manifold. I know they are available for spreadbore Q-jet intakes, but not sure about square bore intakes like your Airgap. If you do get a TBI manifold, my guess is the runners would be matched to the small peanut port heads. These small intake runners and the stock 640cfm throttle body will start choking your 454 by around 4500rpm. You may be able port the intake runners to match your 781 heads, and you can get a ported throttle body that flows 720cfm. Yes you can make it work, but you will still be limiting your HP potential.
- Greg |
#21 |
I like this for Coolness. IDI Hilborn style.
![]() you won't really be able to see a carb under the air cleaner though. And if it is a street driven vehicle, I would much rather have EFI of some kind rather than a carb setup.
#22 |
ok... I'll take 1 multi-port setup please! - to go!
![]() Knowing my setup now... what do you recommend guys (parts list)? I could leave the 750 and the air gap on there. I just thought a nice multi-port system would let me squeeze what little fuel economy I can out of the motor while maintaining as much pwer as possible. The TBI was a gimme but probably not feasible from what I'm hearing. I'm ordering a new 700R4 from TCI this week and B&M converter. Gonna put it in next weekend. Kenny
1987 Chevrolet R10 Silverado BBC Build thread - SOLD 1986 GMC Sierra Classic - SOLD 1957 Chevy Step Side - At the Body Shop Daily Driver; 2005 Chevrolet Silverado 4x4 Z71 Stepside Last edited by 87Lowrider; 11-20-2008 at 11:35 PM. |
#23 |
How much do you have to spend? EFI is expensive...
#24 |
enough ... are there complete systems out there or do you have to piece them together or should I hit the salvage yard?
1987 Chevrolet R10 Silverado BBC Build thread - SOLD 1986 GMC Sierra Classic - SOLD 1957 Chevy Step Side - At the Body Shop Daily Driver; 2005 Chevrolet Silverado 4x4 Z71 Stepside Last edited by 87Lowrider; 11-21-2008 at 08:37 AM. |
#25 |
The '96-'00 Vortec 7400 intake would be a better factory choice than TBI. You would probably need to modify it with bigger injectors and adjustable fuel pressure regulator, then get a custom tune. But this intake does use the large oval runners and should flow enough air to get 500HP or so. You could pick this up on eBay or perhaps in a juckyard for less than a grand. But count on having to replace defective sensors, broken connectors, etc, etc. So the cost could go up.
And yes there are several turn-key aftermarket bolt-on kits. Some are probably better than others. Personally, I would stay away from Holley or Edelbrock controllers. Look at FAST. Their controller is probably the best on the market... but it is very expensive. You could probably piece together a better (cheaper) system by buying a manifold, fuel rail, injectors and throttle body of your choice. Then get a FAST controller and have a wiring harness custom made. This is what I plan to do eventually, but I would use a Megasquirt controller and make my own harness.
- Greg Last edited by 454HO; 11-21-2008 at 11:21 AM. |
