Old 11-17-2008, 10:30 AM   #1
herodcreekfarms
4x4 frame info needed
hi guys i have a 1972 chevy short bed 4x4 and i was wondering if the rear axles/ tires was supposed to sit in the middle of the wheel well or is it off centered towards the front. also is the 1971 4x4 frame the same as a 72 4x4. because the one i have is actually a 4x4 conversion, and i found a 1971 4x4 short bed frame on craigs list, that i am considering buying
herodcreekfarms is offline   Reply With Quote
Old 11-17-2008, 12:08 PM   #2
Yukon Jack
Post Whore
Yukon Jack's Avatar
Re: 4x4 frame info needed
I don't have any good side pics of my 69 before I lifted it, but I do know the rear axle was a little forward of center in the wheel well. Very pronounced after I added larger tires and a shackle flip to lift the rear end.
The 71 and 72 4x4 short bed frame will be the same.
I personally prefer the axle to be centered. When I put a 14bolt in my 70 K5, I did my best to get it centered in the wheel well.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 11-17-2008, 12:19 PM   #3
msgross
msgross's Avatar
There are ways to move the axle back but I did notice that mine was towards the front, they are also narrower in the rear than the front axle...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 11-17-2008, 01:38 PM   #4
Gene Sharp
If you have a lift kit with blocks ,,,,,,the blocks are angled for U-joint alignment adn they also move ther rear foreward a little so you do not have to lengthen drive shaft to make up for lift
Gene Sharp
Gene Sharp is offline   Reply With Quote
Old 11-17-2008, 08:12 PM   #5
jrdv
jrdv's Avatar
ORD-OffroadDesign had a zero rate block that lets you center the rear axle. I used one on my 69 GMC.
Use this link and scroll the the last post.
http://67-72chevytrucks.com/vboard/s...d.php?t=280132
I put a 4' lift on plus the ORD block and I had to have the driveshaft lengthend. If you just put the block on, you probably won't have to lengthen the driveshaft.
john
jrdv is offline   Reply With Quote
Old 11-17-2008, 09:19 PM   #6
71 super
71 super's Avatar
The frames are very very similar, there are a few differences- one being the attach point for the support rod for the e brake- 71 has a tab that is riveted onto the frame on pass. side. 72 does not have this.
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
