11-27-2002, 07:52 AM | #1 |
Rear End ID?
THC W126 2......has Dana type cover gasket.....think it is 3.73 but don't have the book to decode....axle capacity in #s?...out of 71 Burb.....any info appreciated!! THANKS
11-27-2002, 11:34 AM | #2 |
Running on empty
I believe THC means 3.73 ratio;
W indicates Warren assembly plant; 126 indicates the 126th day of the year; 2 indicates the 2nd shift;there should have been a + 0r - sign in between the 126 and the 2 for indicating posi or non-posi; info per Cars & Parts Chevy ID Numbers Book Hope this helps Tim
_____________________________________________ Tim We have two rules here at the Rock. Rule #1: No writing on the walls. Rule#2: Obey all rules 70 GMC Sierra Grande "Custom Camper" Longhorn 402 Big Block TH400 PS PB factory AC Posi; 94 Bronco XLT 302, auto;worn out daily driver |
11-27-2002, 01:54 PM | #3 |
Tim:
Appreciate your help....relooked for the (+) or (-) between the numbers and could not seen any mark...however....I'm way ahead of where I was this AM Thanks Again!!...Jack |
