15" rallye
I am thinking about getting a set of rallyes for my truck..15x8 4inch backspace for the front and 15x10 5 inch backspace for the rear of my 70 1/2 lwb coil springs.. The 5 inch backspace should not cause any problems that I can see..any thoughts would be appreciated...the photo is with 7" rims front and 8"rims rear..thanks
Resident of Here
Re: 15" rallye
I doubt it would cause a problem, but make sure by measuring and know how big a tire you are gonna run.
~Bradley~ 2004 Black GTO LS2/T56 too much to list ![]() Miss having a truck ![]() |
Re: 15" rallye
I don't think it will cause any problems either. If you wanted you could probably run a bigger rim than that. A quick way to guess would be to measure from the mounting pad to the frame rails. With no offset that should be your backspace.
Re: 15" rallye
I am wanting to run the tires I have now..275x60 rear and 255x60 front..thanks
Re: 15" rallye
That should work well and look really nice. The larger wheels will push out a 1/2 inch in front and an inch in back.
Resident of Here
Re: 15" rallye
Most likely tires for an 8" wheel will not work for a 10" wheel. Just remember, measure twice, fit once.
Truck and auto performance nut
Re: 15" rallye
I'm running stock 8" rallys with 275/60-15 BFG's all 'round. I would like to go bigger tho in back with 10" rally's but BFG doesn't make 305/60-15's in the Radial T/A so I'll wait until my other chassis is ready with a 17x8/18x10 stagger.
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
Re: 15" rallye
68gmc.. truck looks great...I will check with my tire guy but am hoping the 275/60 will work on the 10 inch rim..thanks to all
Re: 15" rallye
Re: 15" rallye
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: 15" rallye
Here's my 15x10's with 5" BS. These are also 275/60-15's.
Re: 15" rallye
Lo..looks great and all these photos really help. What width are you running on the front?
#13 |
Re: 15" rallye
I'm running a 7" ralley with 215/70-15's.
