the truck has 4 sp. sm465 i assume, i believe 205, and a 307, dana 44 front and 12 bolt rear.... lift company's are giving me a hard time in getting something to lift this... i would like to use tuffcountry springs, but they are no help saying that the 68's are different than 69 and 70's... what is different.... my truck is a long box and will have to do something about the carrier bearing... what do you guys do????
thanks for a newbie... i have built a k-5 in the past so not uneducated but new to this gen pickup p.s. the 307 is soon to be a boat anchor... zz4 350 with patriot heads, retrofit hyd roller and airgap/truck avenger going in, should be done started and driving by jan ![]() here is ****ty phone pic... it also has man. steering and man. brakes.... i would like to do power steeting... good info on this...???? thanks... been on ck5 for along time but new here... looks great!! ![]() ![]() stretchin legs out a little... 33x12.5's on stock suspension Last edited by Liz; 11-23-2008 at 11:00 AM. Reason: use the edit button instead of double posting |
I'm a poor spectator
Re: questions about my 68 k-20 and lifting it
Have you asked them what the differences are?? I'm curious to know, I thought they would be the same.
2006 Jeep Unlimited IMPACT ORANGE 1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig ![]() 1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!! ![]() 1979 Ford F150 4x4 SWB Built Ford Tough!!! ![]() 1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!! |
something about the spring perches or ???? and they wouldn't fit
wow... no help, crazy... goin back to ck5............... Last edited by Liz; 11-23-2008 at 11:01 AM. Reason: use the edit button instead of double posting |
the perches are different widths eye to eye bro
you can just put perches off a 69-72 to get the lift
![]() Last edited by dinotruck68; 11-17-2008 at 07:20 PM. |
That's a good point. You could do that and flip the rear or use blocks. If you wanted to be different you could use the B52 kit from DIY and have a lot more options for springs and a better ride too.
what is this kit.... i will do a search but help me out here.. what is involved in this... i don't have anything to do serious cutting/welding right now....
nevermind, that is to run 52" springs... i am only going 4" for now... do a shackle flip in rear and ez-rides up front... think i figured this out.... who has similar setup....???? Last edited by Liz; 11-23-2008 at 11:02 AM. Reason: use the edit button instead of double posting |
![]() Join Date: Feb 2001
If you looked around and posted this in the correct forum you woul dhave probably had your answers. Moved. |
Born Psycho
everything on 67-68 suspension and steering is different and springs will need to be custom made OR swap all the mounts from a 69-72 which is what i would recommend. the front spring mounts on your 68 are cast and prone to cracking if your truck is going to be wheeled hard.
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
not 52" lift....
that kit uses the rear 52" springs allowing you to put them on the front of ur rig netting you at 4" of lift or more giv or take.. from what i hear the kit is way better than any other replacement lift kit giving you a better ride. and listen to mudder man that comment u posted wasnt cool.
![]() Last edited by dinotruck68; 11-18-2008 at 06:39 PM. |
after two hours? have fun then....
![]() no comments from me...
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
actually i did post in the 4x4 section... and i wasn't tryin to be rude... lol... was shoppin for parts and needed answer quick....
so how hard to swap out all the spring mounts???? others who have done????? and i know 52" spring... it's what i ran in front of my k5... but at only 4" of lift i don't really need the benefits and travel of 52" spring... |
Well Switching the spring mounts is just a take off the old an bolt on the new type of thing
that way you can just use the tuff country springs
#13 | |
Designated A-hole!
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
#14 |
Catchy title goes here..
![]() Join Date: Mar 2002
#15 |
well if you look closely there is a post in both... but thanks for being a rude ass
and they both have the same title... ill bring it to the top for ya Last edited by Liz; 11-23-2008 at 11:02 AM. Reason: use the edit button instead of double posting |
#16 |
#17 |
He's got mean nasty FANGS!
![]() Join Date: Dec 1999
So you violated rules by cross posting and using language in your post that was censored due to the family friendly nature of this forum. Then you complain we don't answer fast enough then you get answers and call the sites co owner a rude ass? wow, welcome to the forums hope you can act right and make it past this week but I doubt it.
Josh
2004 K2500 Burb 1999 C3500 1985 Cutlass Supreme 1969 C-10 1967 C-10 Panel josh@67-72chevytrucks.com |
#18 |
Designated A-hole!
So that would be double posting which is against the rules. I issued a warning for the rudeness to the staff. I'm trying to cut some slack 'cuz you're new here, but we have a zero staff abuse tolerance. When you have a question please pick ONE area to post it in and exercise some patience. 99.99999% of the time you will get a correct and timely response.
#19 |
Step Brother
IBTL....
#20 | |
hereinmissoula...there is a saying: "Don't bite the hand that feeds you" To make it simple...to make friends and to develop family ties...we treat others like the way we would like to be treated. What one writes and how one writes it reflects on the writer. With patience...you will find that most your questions will be answered by those who are very knowledgable...When one starts to throw stones through the windows of opportunity one will soon learn those windows will be damaged beyond repair.FYI
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! Last edited by 70cst; 11-23-2008 at 12:09 AM. |
#21 |
well i have been on many forums and have never been met with such unwelcomeness.. sorry for being rude to begin with, was in a hurry to order some parts and was half joking to begin with, you all take it seriously and have rude comments even after i expalined and said sorry anyway... so no apology for that, i will not post here anymore if that is the "popular vote" lol..... i have been a corral, coloradok5, stangnet, thirdgen, ls1tech for years and have never had a problem from another member, and i have never been questions about "cross posting" if i don't get an answer in one section, i will post in another that it "fits" in.. which it did... if this is not acceptable i am sorry for that but have not had a problem with before
#22 |
Designated A-hole!
Cross posting is against the rules, being rude is never encouraged and you can stay as long as you like. This is hands down the best place for info on these trucks you'll ever find. But we have rules, we strive to be friendly, family friendly and we appreciate everyone pitching in to help keep it that way. If you don't get the answer you are looking for with your original post you can pm the mod to move it for you. If you have a question about where to post something you can pm a mod for an answer. Is this place perfect, no. Is it the best thing for chevy trucks?, heck ya.
#23 |
A couple "LOLs" or something would have helped.I didn`t get that you were joking.Let`s just get started all over.This site is by no means anything but a friendly community of all walks of life from all over who also like various GM made trucks.You will see that,when needed,the site`s rules are what help keep it that way.Very little policing is required,but it`s there when needed.
Tuff Country is right.Look at any suspension company and you will see GM listed as 69-72.The design changed and the leaf width as well as perches are different.Try our 4wd vendors sticky.I think Alcan and Deevers are there.custom springs cost more,but perform better and that`s all you do,bolt them in.I`d at least look into it. You`ll find alot of guys who hang in the 4wd area also hang at CK5,Pirate,and all the others.So we know where we stand when it comes to rude.
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 11-23-2008 at 10:47 AM. |
#24 |
well i am sorry for the mis-communication.... i do like it here and believe i have something to contribute as well
![]() but now have the 3/4 to be the tow truck to get everyone out of the big mess we get ourselves into, actually works pretty good stock lol |
#25 |
and the fronts are the same correct????.... except the cast perches
i could do ez-rides in the front and custom in the rear... advisable to mix springs like that???? |
