Old 11-17-2008, 08:06 PM   #1
haeusser
Frame table's
I would like to get a thread of all the frame table's and specs for building one possible in one thread. What tubing did you use, stationary, casters,tips,how did you level,etc? Any info would be greatly appreciated, thank you for your time.
-josh
haeusser is offline   Reply With Quote
Old 11-18-2008, 09:46 AM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Frame table's
Anyone?
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 11-18-2008, 12:00 PM   #3
Twisted Minis
Twisted Minis's Avatar
Re: Frame table's
I really like this one that Camburg is building. Its 4x4 and 2x2 tube, with casters, leveling studs, and a blanchard ground top. The part I like is that it is split in two so that it can be re arranged, or stacked for storage. This appeals to me a lot in my small shop.
From what I understand theirs is about 4x16 or so. I figured I would build two 5x5 tables, or 5x6 tables.
If you can find it cheaper, I can fix it!
Twisted Minis is offline   Reply With Quote
Old 11-18-2008, 01:12 PM   #4
abadsvt
abadsvt's Avatar
Re: Frame table's
Well here is my frame table. I don't have the specs on it since i built it a while ago and i am currently out of town for work. I believe it was around 15' 6" (give or take) long and maybe 56-58" wide. The frame was built with 3x3 .120 and have built rolling legs that bolt on to the frame so i can roll it outside. I also designed my frame so it splits the track width difference from the front track width with the rear track width. That way all of the tires are on the frame as close to center of the wheel as possible. If i remember right i think it sits 18" off the ground. I wanted to be able to slide my welder underneath the frame so i could easily move it around. It only has a 10' whip. I really like the look of that frame posted above and maybe next frame jig i might do that then build a rotissery that would bolt on the frame to raise it up and rotate it so i could easily weld the underside of the frame. Anyways here is some pics of my jig.
(Project truck)
1970 C10 under complete transformation
My current build thread http://67-72chevytrucks.com/vboard/s...d.php?t=212871
Other project: C5 corvette swap into 70 c10 http://67-72chevytrucks.com/vboard/s...=1#post2413517 On Hold
abadsvt is offline   Reply With Quote
Old 11-18-2008, 03:25 PM   #5
scotts62
One day...
scotts62's Avatar
Re: Frame table's
Wow thats a cool setup you have going there
Scott
93 crew cab build
Project 62
Old 11-18-2008, 04:53 PM   #6
aggie91
I'm just glad to be here!
aggie91's Avatar
Re: Frame table's
Welcome to the board Twisted Minis (I know you from over on the OFN (I go by kkuenemann over there))
I like that table that you posted from Camburg, but I bet that Blanchard ground top would be HIGH $$'s.
We did something similar to it were I work but we just used a hot rolled plate for the top. I have seen others that had the ground top, but with holes drilled and tap (3/4-10) on a 2" x 2" pattern over the complete surface. I think that would make it much more user friendly and universal.
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 11-19-2008, 12:06 AM   #7
Twisted Minis
Re: Frame table's
Blanchard grinding isn't actually ridiculously priced as I thought it would be, its rather reasonable. However, finding someone that has the capabilities to do a 4x8 sheet is a whole other thing. The shop with the largest capabilities I have found could do 4x4 sheets. I think a blanchard top is more accurate than most people need though. That one is designed to build a few matching trucks with intercheangable parts. Jerry said his will end up tapped every 2 inches like you mentioned.
