Old 11-27-2002, 10:39 AM   #1
special70gmc
special70gmc's Avatar
how low
does any body know how low can i go with the stock leafs on my gmc i wanna lower but dont want to c-notch or convert to trailing arms does ay body know?
1986 c-10 swb 5/7 drop 20'' coys
1958 belair 2door
special70gmc is offline   Reply With Quote
Old 11-27-2002, 10:48 AM   #2
crazy longhorn
Fabricate till you "puke"
You should be able to go 4-5" on the leaf suspension without notching. At 5" drop, you will be pretty close on the axle to frame clearance (as far as hauling any heavy loads). My longhorn frame is a little different than a standard longbed, but i have flipped the axle & relocated brackets to give about 5" drop. I have 2 3/4-3" tween the frame & axle......
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 11-27-2002, 12:11 PM   #3
Ackattack
Ackattack's Avatar
i removed all but 3 leafs on my truck and I have about 2.5 inches between the rubber bouncer and frame.
Ackattack is offline   Reply With Quote
