Old 11-17-2008, 10:03 PM   #1
Larry S
Larry S's Avatar
5.7 mounting question
I have a 1996 5.7 engine I am trying to place in my 71-72 frame. I tried to set it down in the frame today, and the stock manifolds hit the frame before the mounts will sit down on the mount stands. Ive never tried to put a vortech in this year truck but know it can and has been done. The mounts look like they will line up if the manifolds were removed, allowing the engine to go down. Also what crossmembers will need to be removed, relocated or added to accomodate 5.7/ L460e? Thanks for your time!
Larry S is offline   Reply With Quote
Old 11-17-2008, 10:25 PM   #2
Ram-Man
Ram-Man's Avatar
Re: 5.7 mounting question
Are you motor mounts correct for that year sb. What was in the truck before? The 6cyl and 8cyl mount towers that go from the frame to the crossmember are different.
Porterbuilt 8 Lugger
http://67-72chevytrucks.com/vboard/s...d.php?t=691739
Ram-Man is offline   Reply With Quote
Old 11-17-2008, 10:31 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
you just need to get the correct manifolds for a 67 - 72 4X4, or headers.
The tranny cross member will need moved... that's it.
Old 11-17-2008, 10:31 PM   #4
Larry S
Larry S's Avatar
the frame im using was a 6 cyl truck. I already changed the mount towers and believe they are correct. I looked at a friends 72 with a 350 in it and the towers im using look like his. I just pulled the mounts off one of the old inline 6cyls i have and they bolted on the vortec, but Im wondering if the mount height is the difference. thanks
Old 11-17-2008, 10:51 PM   #5
nicolas72gmc
nicolas72gmc's Avatar
Larry, I will be following this one, I am doing the same exact thing. My engine and trans is the exact same year you are installing. A write up with pics would be nice.
Nick
"Everyone has a plan, 'till they get punched in the mouth".........Mike Tyson
1968, GMC, SWB, Project
1972, GMC, LWB, Daily Driver, 383, headers, 2.5"/3" exhaust, 200r4, 3.5/5 ECE components.
1972, C/10, LWB, 350 vortec, th350
nicolas72gmc is offline   Reply With Quote
Old 11-17-2008, 11:05 PM   #6
Larry S
Larry S's Avatar
Ok. Im going to get some new correct mounts for the 5.7. The ones I stuck on there are a "lil hairy" but Im thinking the manifolds are the problem. If the manifolds werent on there it looks like it would sit right in. Will a set of headers off 67-72 350 fit 1996 5.7? Thanks
Old 11-17-2008, 11:24 PM   #7
nicolas72gmc
yes
Nick
Old 11-18-2008, 12:13 AM   #8
Chevymann1968
Chevymann1968's Avatar
Please keep all ads in the classified sections only.
1968 GMC
Rebuilding Stage
2001 Camaro SS SOLD
Chevymann1968 is offline   Reply With Quote
Old 11-18-2008, 12:51 AM   #9
DirtyLarry
Windy Corner of a Dirty Street
DirtyLarry's Avatar
Meh, headers are just a good way of ruing starters and keeping yourself busy chasing exhaust leaks. Keep the later model exhaust manifolds. I just finished a similar deal into a ’72 and wanted to keep the EFI manifolds for the sake of keeping the O2 sensor in the manifold rather than putting an O2 bung in the exhaust pipe. I ended up using 1976 engine towers to clear the exhaust manifolds.
Thread here…. http://67-72chevytrucks.com/vboard/s...d.php?t=306106
DirtyLarry is offline   Reply With Quote
Old 11-18-2008, 01:34 AM   #10
mr48chev
mr48chev's Avatar
Longhornman nailed it. The later style drop down manifolds won't work in these trucks. You need ram horn manifolds or headers.
Old 11-18-2008, 02:15 AM   #11
smoky02
Location: Sunny, Florida, some might call it South Alabama
I have a 98 Vortec 350 and 700r4 in my truck. It sits in it just like an older 350 and TH350. But you have to cut the brace out that the I6 mounted to, and you are also gonna need to put a auto steering column in your truck. I didn't recieve the stock manifolds with my motor so I just bought a good set of headers
Just sold my C10...sad day...
Looking for a 1972 Blazer to hopefully fill the hole in my heart.
smoky02 is offline   Reply With Quote
