Old 11-18-2008, 08:33 AM   #1
eightbanger
454 MAKES IT ROAR
eightbanger's Avatar
Side marker bulbs?
Can anyone tell if the small bulbs in the side marker/blinkers lights on the front fenders and on the bed should be dual filament or single. I thought they would need to be dual, as when the lights are on at night as running lights the second filament would be needed to blink brighter for turn signal use.
Also the bulbs and fittings in my side markers are the push in type the same used in the instrument panel.
Hope i've described this properly.
Nigel.
An American living in a British body.
1971 Chevy Cheyenne 10 454
"In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell
"When injustice becomes law, resistance becomes duty" - Thomas Jefferson
No more pain.
03.12.60 -- 12.28.10
http://www.youtube.com/Eightbanger
eightbanger is offline   Reply With Quote
Old 11-18-2008, 08:44 AM   #2
71stub
71stub's Avatar
Re: Side marker bulbs?
I think they are just a 194 single element bulb.
1971 Cheyenne Short Fleet - 468BB/TH400, Tilt, Tach, PS, PB
1967 Custom Short Fleet - 327/4spd
71stub is offline   Reply With Quote
Old 11-18-2008, 08:49 AM   #3
eightbanger
454 MAKES IT ROAR
Thanks 71stub, are your bulbs the same type as mine? the reason I ask is that the parts stores only seem to stock the metal cap twist in type for side markers.
Nigel.
No more pain.
Old 11-18-2008, 09:04 AM   #4
Andy4639
Old member
Andy4639's Avatar
Single element but the fronts blink and the rear don't when turn signal is on. NAPA has them and Oriley's, Advance Auto.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 11-18-2008, 09:52 AM   #5
eightbanger
454 MAKES IT ROAR
Thanks Andy, but the prob I have is that i'm almost possitive that when I bought the truck the rears blinked. I'm sort of backed up on this as I had to replace my original US blinker relay when it gave up with a new relay here in the UK, and UK relays are designed to make a faster clicking sound to let the driver know that a bulb may be out or that there is a fault with the blinkers. And that is exactly what happened it worked fine, then one day the relay in the cab started clicking real fast when I put my turn signal on and the only lights not blinking were the rear marker lights.
Also they don't flash on Hazard.
Nigel.
No more pain.
Old 11-18-2008, 10:21 AM   #6
Andy4639
Old member
Andy4639's Avatar
Take the back ones loose and see if the grounds are good. I have the 71 model deluxe and my back side markers have never flashed.
Old 11-18-2008, 11:07 AM   #7
71stub
71stub's Avatar
My rears have never flashed either.
Old 11-18-2008, 11:15 AM   #8
eightbanger
454 MAKES IT ROAR
At the end of the day i'd trust your advice Andy before I would my trust my own memory....and i'am driving an American Truck so who's better placed to know than an American.
Thanks guys I'll stop pulling my hair out over this and consider them working as they should be....unless others say different...then i'll start pulling.
Nigel.
No more pain.
Old 11-18-2008, 11:37 AM   #9
Andy4639
Old member
Andy4639's Avatar
This is with the light swich off and blinker on. Front flashing rear's aren't. Hope this helps.
With light switch on and blinker on. Front blinking and rear's aren't. The parking lamp is on though.
Old 11-18-2008, 11:39 AM   #10
sick69
sick69's Avatar
The only rear side marker lights I've seen flash had been rewired to flash. I am 99.9% sure they didn't flash from the factory.
Frank
70 chevy lwb c10
454/th400 and a 9" rearend
suicide doors, marker light fuel fill, 4" cowl , mini tub
sick69 is offline   Reply With Quote
Old 11-18-2008, 11:46 AM   #11
WIDESIDE72
WIDESIDE72's Avatar
They do not flash from the factory. My Dad had a 72 lwb Custom Deluxe new and uncle had a 72 Cheyenne new (brother has it now). Neither truck rear side lights blinked.
WIDESIDE72 is offline   Reply With Quote
Old 11-18-2008, 05:31 PM   #12
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
This is correct, the rear side markers never flashed from the factory... not even required to by todays DOT standards.
The front, some of them flashed, some did not.
Your 4 ways not flashing... try swapping your two flashers around, one for the other. They are the same part number unit, so if swapping them fixes it, you know what you have to do.
And finally, for the original question, the above is 100% correct, single, not double. When the parking lights are on, and the side markers flash, it isn't brighter than running lights, it turns on and off.
194 bulbs are the correct number, in american cars they have been the norm since the late 60's in the inst pannel, and are still used today, but not as frequent as back then.
Old 11-18-2008, 06:18 PM   #13
eightbanger
454 MAKES IT ROAR
Thanks you guys for all your help...Andy4639 thanks for taking the time to post those pics. It's always nice to find out you haven't got a prob when you thought you did...that's the easiest fix of all
Nigel.
No more pain.
Old 11-18-2008, 06:41 PM   #14
Andy4639
Old member
Andy4639's Avatar
That's why we are here because we all want to help each other no matter where we live.
