Old 11-18-2008, 10:41 AM   #1
Scott Johnson
Junior Member
Scott Johnson's Avatar
Radiator Question
I need a new radiator for my truck, 71 1/2 ton 350 auto, a/c. Will a 2 row aluminum radiator cool as good or better than a 4 row copper?
71 C10 Step Daily Driver
72 K10 Suburban Work in Progress
www.louisianaclassictruckclub.com
Scott Johnson is offline   Reply With Quote
Old 11-18-2008, 11:16 AM   #2
Andy4639
Old member
Andy4639's Avatar
Re: Radiator Question
You can buy a new 4 core pretty cheap now. Look at Napa or Advance.
I don't know if it would or not but if you have to pull a trailer or A/C I would stick to a 4 core.
http://www.partsamerica.com/ProductL...ype=31&PTSet=A
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 11-18-2008, 05:37 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
In all reality, that should do fine. A 2 row brass copper was the standard rad for a small block truck w/out a/c, and with the added cooling abilities of alluminum, you should be fine.
Old 11-18-2008, 06:17 PM   #4
msgross
msgross's Avatar
www.rockauto.com has some decent lower priced radiators.. about $225
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
