73-87 tach question
all of the tabs on my tach dash are broke off. can i take a non tach set up and take out the gauges and replace them with the tach setup? pics of the non tach set up and the tach set up would be nice so i can see if there are any diffrences
Greater love hath no man than to lay down his life for a friend. Members i Have met Earl Slick68 1969 Stepside Build thread http://67-72chevytrucks.com/vboard/s...=1#post4253546 ![]() ![]() |
yeller
Re: 73-87 tach question
The actual cluster housings are different, so the short answer in "no you can't".
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
could i mod the non tach cluster?
Yo! My '76 Camaro had the same problem and I was able to fix it permanently with some sheet metal strips wrapped over the old tab positions and some polyesther body fill to fix the sheetmetal in place on the instrument housing. When I completed the repairs, I also converted my old instrument cluster from "idiot lights" to guages and swapped the "giant" fuel guage to a tach. I'd be happy to direct you to my cardomain.com thread and some pics if you're interested. Todd.
In the Forgotten far North.
![]() Join Date: Jul 2007
Yes you can The part that the tach mounts to can be unscrewed from the main body leaving a big gapping hole in the back of the housing.
1. disassemble the tach dash and unscrew the tach mount from the main body. Then dismount the tach from the tach mount itself. 2. Set the main body onto a piece of heavy construction paper (manila folders work great) and trace out the tach mount opening. You will see three(3) mounting points in the back of the cluster housing the corospond with the tach mount. 3. Cut out the pattern from the paper and use it to outline the aera you need to cut out by taping it to the INSIDE OF THE CLUSTER HOUSING making sure you line it up properly then using a hot knife (heating up an x-acto knife blade will work) Then all you need to do is swap over the four small gauges and the printed circuit on the back. You can use your original speedometer with it as well. I did something similar to this just over a year ago myself but it was alot more extensive.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015 1990 chevy suburban V2500 5.7L My cluster Mods-Nov 2007 overhead console Stereo install Round 2 Aug 2009 Heated/turn signal mirror upgrade |
Yo! Found it and dug it out of "storage"! Here's the link I was referring to:
http://www.cardomain.com/ride/639261/3 Todd. |
