Old 11-18-2008, 06:47 PM   #1
a1953mdl
Rusty but Trusty
a1953mdl's Avatar
Narrowing front track width
Has anybody modified there front suspension to tuck the wheels in more for rolling low ?
Like maybe cutting the control arms down in length to bring the whole spindle & wheel inward ?
I know the PB-DM narrows it a few inches, but Im not looking to spend that kinda money
Just a thought that I had & wondered if it had been done, or if its just not worth it
Lee
72 SWB, 454 / th400... hoping the kids don't get all the parts before it gets built
a1953mdl is offline   Reply With Quote
Old 11-18-2008, 07:43 PM   #2
PBFAB.COM
PBFAB.COM's Avatar
Re: Narrowing front track width
The "easiest" and less involved way would be to narrow up the control arms, and outer tie-rods. The only drawback to this is the increased camber and caster changes resulting in shorter control arms.
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 11-18-2008, 10:07 PM   #3
protrash64
Resistance is Futile
protrash64's Avatar
I saw this done in Truckin' to a suburban to tuck 22's. It was a few years ago and they cut 1" out of the upper and lower control arms.
May have been Steet trucks...cant remember. Was a 63-66 'burb.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 11-19-2008, 12:50 AM   #4
a1953mdl
Rusty but Trusty
a1953mdl's Avatar
Thanks for the replies. I just wanted to make sure i was thinking correctly.
I understand the increase changes in the caster/camber. And may decide to live with it for the lower stance and dump ability.
Wish I had the money right now for a "PORTER BUILT" drop member. You have some great prices going on those right now. Maybe i need to sell a few things and do it right.
Can't look thru the old magazines right now, built think I have the ability to mod the arms and tie rod ends.
Lee
Old 11-19-2008, 09:57 AM   #5
N2TRUX
Happy to be here
N2TRUX's Avatar
I have seen this done as a method of lowering too. Since you have to add a plate to weld the sections of the A-arm to you can raise the balljoint area and gain some drop from it. Just be sure to gusset everything...twice.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 11-21-2008, 02:03 AM   #6
nuke1
nuke1's Avatar
or you could section a few inches out of your crossmember and narrow it and your frame rails at the same time, i would prefer that over the control arms....
James
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 11-21-2008, 09:39 AM   #7
N2TRUX
Happy to be here
N2TRUX's Avatar
Originally Posted by nuke1 View Post
or you could section a few inches out of your crossmember and narrow it and your frame rails at the same time....
James
That seems like a lot more work to me. Why would you prefer this method?
Articles-
"Refining Sierra"
Old 11-21-2008, 10:57 AM   #8
Shane
Shane's Avatar
I had a '78 2wd blazer that was lowered and narrowed using this method in the front. Worked marvelous!
Shane is offline   Reply With Quote
Old 11-21-2008, 12:24 PM   #9
SCOTI
SCOTI's Avatar
I have some 6X-72 lower arms that have 1" sections removed between the BJ & spring pocket to keep the track width as narrow as possible.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 11-22-2008, 12:18 AM   #10
lotik
drag it like you stole it
i think IF Customs has some pics of some a-arms for these trucks that they shortened. www.ifcustom.com
negative camber //LA\\
lotik is offline   Reply With Quote
Old 11-22-2008, 01:03 AM   #11
Dustin07
Stirrer of the Pot
on gmfs a guy shortened the trackwidth by shortening the lca and recessing the uca mounts if IIRC. I heard it created some new problems but I can't verify. he raised his UCA's too to fix camber when laid out. I only heard good things bout it. It's a newer chevy though, like 05.
Dustin07 is offline   Reply With Quote
Old 11-22-2008, 05:42 PM   #12
lowestsixty7
I narrowed the upper and lower control arms on my 67' C10.
lowestsixty7 is offline   Reply With Quote
Old 11-22-2008, 05:47 PM   #13
lowestsixty7
You have to do a little work once you cut them and tack them back together to make them look like factory. Sorry couldnt find any pics of them welded back together.
