Old 11-19-2008, 01:26 AM   #1
combustion
oil pressure within spec?
up untill the point i installed my 454, i never really looked at my oil pressure guage.it never drops down below 1/4 of the way down. here is what my guage indicates.
fully warm @ idle 650-700 rpms
should i be worried?
other info..
when its cold it pegs all the way to the h because the viscosity of the oil is thicker.
also when im reved to about 1500 rpm's (FULLY WARM) it goes about 3/4 up closer to the H. which is good. anything past 1500 it pegs the H (FULLY WARM). <-- this is normal right?
so in a nutshell, should i be worries about my idle oil pressure? is it too low at idle?
If it`s 3.73 ratio you will spint the wheel 100 times to the driveshaft`s 373 times.Or,if you`re lazy,you could just spin the wheel once and the driveshaft will spin 3.73 times.Or, 3 and 3/4 turns.And if you`re real lazy,I can sell you a tab for whatever ratio you want.
Or,you could read all the suggestions and try those.It`s been well explained,I think,already.
combustion is offline   Reply With Quote
Old 11-19-2008, 01:38 AM   #2
jamieg
Re: oil pressure within spec?
i would recommend a manual pressure test with a known good gauge just to ease your worries.
jamieg is offline   Reply With Quote
Old 11-19-2008, 01:39 AM   #3
C10-Driver
Chevy Truck Addict
C10-Driver's Avatar
Mine used to run around the 1/4 mark, warmed up at idle... I would probably not worry too much about it. I believe most of the factory gauges were rated for 60psi so that would suggest you're getting 60 or more within operating range which sounds good to me. I ended up replacing the factory gauge with an aftermarket so I could read a dial with numbers on it.
1970 Chev C/10 SWB, 355 SBC, 700R4, 3.73 Posi, Air Ride (Click to view Build Thread) (SOLD)
1978 Chevy C/10 SWB
1970 Pontiac Lemans
C10-Driver is offline   Reply With Quote
Old 11-19-2008, 06:54 AM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
That would indicate 15-ish PSI
Old 11-19-2008, 07:01 AM   #5
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
The guideline is 10 pounds of pressure per 1000 rpm. You look plenty safe to me. Is the valvetrain quiet at idle ?
Old 11-19-2008, 08:46 AM   #6
70GMCer
70GMCer's Avatar
x2.......10psi per 1000 rpms avg. at normal engine temp.
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 11-19-2008, 10:30 AM   #7
chas350
Looks normal to me, as long as the pressure starts to come up with rpm increase.
"I'll Procrastinate Tomorrow"
quote by LEEVON
71 K10 long fleet (sons truck) new 370hp 355, sm465 np205, 3.73's 33's
70 K20 long fleet
98 G3500 work van
chas350 is offline   Reply With Quote
Old 11-19-2008, 10:40 AM   #8
67ChevyRedneck
67ChevyRedneck's Avatar
My 67 reads pretty low at idle, around 17-18 psi, but is more around 40-50 psi while cruising.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
