Old 11-19-2008, 10:13 AM   #1
JAB'70
A little "Shock" advice...
Seeking advice from the experts. Driving a '70 c10, with rear coil and leaf. Want to put on new shocks, any recommendations? Street driving only...
JAB'70 is offline   Reply With Quote
Old 11-19-2008, 10:26 AM   #2
myoldchevytruck
Retired Air Force Veteran
myoldchevytruck's Avatar
Re: A little "Shock" advice...
For Stock Shocks, I've seen allot of members using KYB Shocks. I am going to use either Belltech or Toxic Drop Shocks for my lowered 69' Stepside. Right now, I have a 3/6 drop but do have plans to bag it.
Harry
69' SWB Step Side 1/2 Ton w/68' Front Clip
Swap from Leafs to Trailing Arms (Complete)
Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front)
3/6 Drop
Help Support The Board
Click Here For Information On How To Subscribe
Krue's FAQ Page
Vendors
myoldchevytruck is offline   Reply With Quote
Old 11-19-2008, 11:35 AM   #3
C10-Driver
Chevy Truck Addict
C10-Driver's Avatar
I'm using Monroe SensaTrac and am real happy with them. I believe quite a few others on the board are running them too.
1970 Chev C/10 SWB, 355 SBC, 700R4, 3.73 Posi, Air Ride (Click to view Build Thread) (SOLD)
1978 Chevy C/10 SWB
1970 Pontiac Lemans
C10-Driver is offline   Reply With Quote
Old 11-19-2008, 12:20 PM   #4
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I like KYBs for either stock or lowered trucks. They are money well spent.
For stock height trucks, buy them from Summit or local parts store.
If your truck is lowered, ECE sells the proper short KYBs.
Old 11-19-2008, 03:13 PM   #5
BigDaddyDave
RIP BigDaddyDave ~7-23-09~ You will be missed~
BigDaddyDave's Avatar
I put KYBs on mine,it was dropped 2/4 and i think it rode like crap.I will use different shocks the next time.
BigDaddyDave's Truck: http://www.flickr.com/photos/daves71chevy/ | See it in Action!
BigDaddyDave is offline   Reply With Quote
Old 11-19-2008, 04:02 PM   #6
Brad
Out of the carpool lane.
Brad's Avatar
I've had KYB's and they're stiffer than the SensaTrac shocks.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red
1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!)
2000 Honda VFR in the faster yellow!
2008 Husqvarna TE-610
1967 C-10 SWB 'Six Appeal'-Gone but not forgotten...
Brad is offline   Reply With Quote
Old 11-19-2008, 04:35 PM   #7
VDOG
Grand PooBaa Member
VDOG's Avatar
Im running CPP shocks and lowering springs 3/5 drop. My truck rides like a dumptruck!
It rode smoother with the 38 year old suspenssion. I hear guys saying there trucks ride smooth once its changed over, but I have not seen it yet.
VDOG is offline   Reply With Quote
Old 11-19-2008, 05:28 PM   #8
leddzepp
Moderator
leddzepp's Avatar
When you change to lowering springs, you will definitely lose ride quality. Airbagging is the way to go to maintain ride quality, while getting the lowered stance. If you cannot afford air bags and do not want ride quality to suffer, I would go no lower than 2.5" in the front, using dropped spindles, NOT springs.
leddzepp is offline   Reply With Quote
Old 11-19-2008, 05:58 PM   #9
VDOG
Grand PooBaa Member
VDOG's Avatar
I used stock height spindles when I did my upgrade. Also used heavy duty springs in the rear in case I carry a small load. The guy at CPP said it would be the same smooth ride if I got the regular springs. I think he was wrong.
Old 11-19-2008, 06:00 PM   #10
Tx Firefighter
Keep in mind, there are two levels of KYBs. The Gasadjusts (white in color ) are super stiff and the GR2s (grey in color) are much softer.
I've had more than a handful of deeply lowered trucks with KYB GR2s and none of them have ridden worse than stock truck did.
Old 11-19-2008, 10:31 PM   #11
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
rear coil and leaf?????????
2 wrongs don't make a right, but 3 lefts do.
66 Chevelle Malibu 406ci, 573hp, 10.99@121mph
96 Chevy Silverado Z71
72 GMC 1500 Super Custom LS 6.0/4L65 on airride
http://www.cardomain.com/ride/707879...mc-c-k-pick-up
chevydog66 is offline   Reply With Quote
Old 11-20-2008, 09:54 AM   #12
JAB'70
Thanks appeciate the info...I'm leaning towards the Monroe Sensa Tracs...Chevydog, Yep!! Rear coils and Leaf...
By the way TX, excellent info on installing the sway bar, I just finished the install yesterday and your posts were a big help and saver of time...
Old 11-20-2008, 11:24 AM   #13
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
I am running KYB's on the aft of my '69. The comfort of the ride far exceeded my '96, before I "fixed" the late model. I have 4-inch drops on both, the difference being coils on the early one and leaves on the later one. On the '96, I installed Toxic Shocks. The piston shaft on them is huge x large. DJM didn't offer/recommend an upper shock mount relocator when we did the lowering in '01. However, after getting the truck back from CA in '06, and doing some trading w/youngest son, I have the '96 and got tired of the poor ride. After getting a pair of upper shock mount relocators from BellTech, and getting them installed, I have a lot better ride, but is still isn't as comfy as the coil-sprung '69. I am also running SensaTracs on the rear of the '96. As to a replacement shock, I went to my NAPA store and looked at their shock catalog. I located the stock shock (length/mounting), then looked for a shock that had the same upper/lower mountings and was approximately 4-inches shorter (only applies to the rear). For the front ends, both were lowered with spindles and that doesn't require anything but a stock-length shock. If you use cut/shorter springs to lower the front, you'll need shorter-length shocks.
My point is saying all this is that if you lower your truck 4-inches, you really need to do the shock relocation step. It will restore the correct angle to the shocks and you will be able to count on a nice, comfy ride. If you don't, the shocks don't work properly, effectively holding the body away from the axle, almost to the point of being rigid.
Member Nr. 2770
Old 11-20-2008, 11:30 AM   #14
67ChevyRedneck
67ChevyRedneck's Avatar
You mean you have a coil spring rear suspension with helper/overload leaf springs at the back of the frame? The suspension won't come in contact with the leafs until the truck is really loaded down. Is that what you have?
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 11-20-2008, 02:52 PM   #15
MonteSS454
MonteSS454's Avatar
I had rear coil over springs and leafs on my 71, but I got rid of the coil overs and went with Monroe Reflex's all the way around.
MonteSS454 is offline   Reply With Quote
Old 11-21-2008, 11:02 AM   #16
JAB'70
Yeap, pretty what it is....
