super budget gas tank...
Ok I got a sweet deal on a 66 lwb with a bed of parts. Have been doing the body work and stuff like that. I want to replace the brand new tank from in the cab to out of the cab unit. The plan is a super TIGHT budget on this truck, but trick it out as much as I can. The dare was to build it for $6k or less and make it lay frame. So every penny counts. Any ideas whats a budget minded way to do this tank conversion? I have checked out the tank kits and it would be like $350 for everything to make it work.... just want to make sure thats the cheapest way. Did I mention the $6k was paint and wheels also!! I love a good chanllenge
One day...
Re: super budget gas tank...
There is another tank that you can get for the back thats around $200 with sending unit, i cant remember the link though, im sure one of the other guys will post it up real soon though.
Do a search in the forum for fuel tanks there is all sorts of different ways the guys have done theirs. Last edited by scotts62; 11-19-2008 at 11:31 AM. Reason: oops |
This will save you a buck 50.
http://www.lmctruck.com/ICATALOG/CBE/full.aspx?Page=67 |
Its Deja Vu time again
Thats where I saw that. I saw another that was stainless or whatever and they wanted around $750.
One day...
yep thats the one i was thinking of too.
The cheapest way is to use a tank from another vehicle and not buy new. Adapt it and make it work. I'll probably use a tank from and Astro van or a Jeep tank that I've already got laying around. Cost = priceless
66 Chevy Stepside tandem project My junk: http://67-72chevytrucks.com/vboard/s...d.php?t=480902 Last edited by HotRodYJ; 11-20-2008 at 07:51 AM. |
Jeep Wrangler looks pretty close to the same shape as that LMC truck catalog, 19gallon and made out of that poly/plastic stuff. Heck grab a stocker and I'm sure you could grab the 1/8 steel box they call a armor which happens to have the holes for hanging it.
Heres what an aftermarket skid looks like, but you can see the square holes in the rear that that straps use. I have a 2000 wrangler if anybody needs measurements I could take them. Heres how it was installed if anybody wants to bother looking at it as well it shows pictures of the Jeep tank. http://www.jeepaholics.com/feature/k...id/default.htm TJ, the round headlight one fills from the drivers side, YJ square headlights fills from the back, however I'm sure you could remove the clamps and add new hoses. |
Most of the conversions with a factory style tank instead of a fuel cell just use a stock Blazer fuel tank.
66 Chevy Stepside tandem project My junk: http://67-72chevytrucks.com/vboard/s...d.php?t=480902 |
Here is what I did. Tank is out of a late 70's-early 80's 1/2 ton Chevy Van. Welded a 3X4 piece of angel to the end of the bed rails and drilled for the hangers. Also had to trim the lower edge of the upper X-member slightly and the one cross sill. Hole sawed threw the frame for the fuel fill and used a 88'-98' Chev Pickup gas door. I think I paid 35.00 for the tank fuel fill neck and door.
1963' Chev Custom Cab 502, 67' 435hp 3X2 intake, 9" 4:30 Posi 1961 Impala SS 348/350 4-speed 3:70 Posi 1961 Bel-Air Bubble Top 283 Turboglide soon to have a 348 3X2 4-speed 1950 17' Fairliner twin cockpit barrel stern 312 Y block 1X1 intake Borg Warner 1:1 gear 1957 Fleetform 14' twin cockpit barrel stern 1969 BP-125 Merc 1949 Transitier 3-wheel forklift Crosley 4-Banger 98' FXD 2002 2500HD |
Couple more pics...
502tripower,
From the looks of it you cant see your tank at all with the bumper mounted. Any idea if you would see it if you had just a roll pan attached or do you think it would be hidden? |
The roll pan does hide the tank completely.
#13 |
502 I like that set up. Looks clean.
thanks for the ideas guys. |
#14 |
502, Is that purple heart bed wood I see?
#15 |
![]() Join Date: Oct 2006
Maybe this will work for you ....
http://www.67-72chevytrucks.com/vboa...d.php?t=234732
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " Last edited by slepysal; 11-20-2008 at 06:59 PM. |
#16 |
#17 |
One day...
I like that! looks good 502
#18 |
New Member
![]() Join Date: Feb 2007
summit racing has some to choose from. i might go with this setup if i don't build my own.
http://store.summitracing.com/partde...5&autoview=sku
1968 SWB Project. Soon to Start Build Thread |
#19 |
FYI, The "Blazer" tank which LMC and others sell is also found in the more common Suburban.
'65 Chevy shortbed stepside. |
#20 |
I used a 66 mustang tank, the cost was around $100 with sending unit
#21 |
#22 |
not shure if the sending unit works, because the tank is just mocked up in the frame as of now
#23 |
How about some pics
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
#24 |
man i wish i could, ill try to borrow a camera, by the way i have a custom back half but i did have it on the stock frame before i built the backhalf, the spout came up through the floor
#25 |
1961chevy:
Welcome to the boards from Kansas City, KS. jmedero: Keep us posted with your progress. |
