Old 11-19-2008, 11:31 AM   #1
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
has anybody swaped rear ends (diff axle and all)
Im lookin for beter gas mileage in my truck....is there a whole axle assembly out of another vehicle possbily that would maybe have a higher gearing or something....jw maybe im just all screwed up...but curious to see if anybodys pulled a rear end outa another vehicle or truck that'll bolt up to a 68 lwb fleetside.....lookin for gas mileage here thanks
John
1999 Toyota Tacoma 4x4
Old 11-19-2008, 11:33 AM   #2
drewdude92
72 chevys 4 life
drewdude92's Avatar
Re: has anybody swaped rear ends (diff axle and all)
i would like to know this also ....bump
I dont call it being young and dumb....I call it young and havin fun
drewdude92 is offline   Reply With Quote
Old 11-19-2008, 11:37 AM   #3
nightmare
nightmare's Avatar
i don't think that this is possible with coil spring trucks. IIRC there were no other vehicles that had that type of setup. If you have leaf springs, you may have more choices, like from a newer chevy/gmc pickup. But even then you may have to move the perches that the axles sit on.
you may want to look at getting a numerically lower gear ratio to boost mpg. but i think that the lowest you can go is 3.08's.
Mike
2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip
1972 Chevy Suburban - Turquoise/Black
1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD
Using your turn signal is not "giving information to the enemy"
67-72 FAQ
Originally Posted by GMCMAX View Post
My lugnuts require more torque than your honda makes!
nightmare is offline   Reply With Quote
Old 11-19-2008, 11:40 AM   #4
LuckyHenriksen
LuckyHenriksen's Avatar
Can't you just find a rear end out of the same year of truck but with 3:08 gearing?
1968 Yenko Chevy LWB
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
LuckyHenriksen is offline   Reply With Quote
Old 11-19-2008, 11:43 AM   #5
nightmare
nightmare's Avatar
yes, that is possible, but my understanding of the initial question was to find an axle out of a totally different vehicle. my mistake if i misunderstood.
Mike
67-72 FAQ
Old 11-19-2008, 11:57 AM   #6
Bus Ted Knuckle
Son of a gun
Bus Ted Knuckle's Avatar
You can weld the mounts you need on any axle housing.
BEATERS ARE NEATER
Bus Ted Knuckle is offline   Reply With Quote
Old 11-19-2008, 12:18 PM   #7
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I've put several 73-87 rear ends in these old coil spring trucks. ECE sells the weld on axle saddles. These in conjunction with a super track bar in place of the panhard bar and you're all set.
The advantages are same wheel bolt pattern, proper width, and a large selection of ratios. Many of these trucks came with 2.73, 3.08, or 3.40 gears.
Old 11-19-2008, 12:34 PM   #8
nightmare
nightmare's Avatar
correct. all i'm saying though is to find an axle out of a totally different vehicle, that will just bolt right in, is almost impossible. anything is possible with a welder.
Mike
67-72 FAQ
Old 11-19-2008, 01:07 PM   #9
jorgensensc
jorgensensc's Avatar
Sounds good, unfortunately there isn't a boat load of these trucks laying around (at least in this area) that have good rear ends and trying to find the right gear ratio. Not to mention 33 + year old parts like to brake.
If it were me i would measure the rear width and hit up a junkyard to find a newer rear, then just buy the correct saddles and weld them on (or have them welded on). You might even be able to get a rear disc brake setup too. Yours is 5 lug right? If it was 6 lug the newer rear ends are aplenty.
Shawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 11-19-2008, 01:11 PM   #10
jholley
jholley's Avatar
I have a 3.08 Posi in my 69 that I'm probably going to be getting rid of soon if you're interested. I just scored a 4.11 Detroit Locker that I'm going to use.
Jim
Garage fillers...
85 Chevy C10 Silverado LWB
07 Nissan Altima
2006 Mini Cooper S
jholley is offline   Reply With Quote
Old 11-19-2008, 01:51 PM   #11
67ChevyRedneck
67ChevyRedneck's Avatar
What gear ratio do you have now?
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 11-19-2008, 02:20 PM   #12
2bits
2bits's Avatar
I have a 73-87 Axle on mine, running 2.73's and it has plenty of power and I like the highway gears, I am not a racer. Yes it is NOT a bolt in set up, you need to weld the new axle saddles on and grid off the leaf spring saddles and shock mounts. Just make sure the axle is the right length. You might have to get an aftermarket trackbar if the new rear end doesn't have the mount for it too. Not that hard depending on what tools you have and how bad you want it. I had to do mine. Probably a better idea to take the existing axle housing and swap out the gears for you.
_______________
Thomas
'78 Silverado
'74 Monte Carlo
'47 Teardrop Trailer
East Texas Classics Local Club
2bits is offline   Reply With Quote
Old 11-19-2008, 02:46 PM   #13
chevy_mike
Never Ending Projects
chevy_mike's Avatar
This is exactly what I am doing with mine. I have a rear end from a '74 with 3.40 gears, already cut and ground the old mounts off and after I clean up my trailing arms, I will put it in with the ECE saddles and super track bar. Nice thing is that it's 1.5" wider then my '68 so it will match the track width when I put the disc brakes up front.
I am also putting discs on the rear too.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 11-19-2008, 02:50 PM   #14
Tx Firefighter
Bobcat ?
Old 11-19-2008, 03:11 PM   #15
BigSky71
LAIDOUT
BigSky71's Avatar
Fwiw its worth my truck gets the same mileage with the stock 3.55s as it does with my now 2.75s, mind you this is about 1/3 highway and 2/3 driving around town.
I think you will need to do a fair amount of highway driving for the cost of the rearend change to work out savings wise.
67 2wd Shorty
Build Pictures
BigSky71 is offline   Reply With Quote
Old 11-19-2008, 03:15 PM   #16
67ChevyRedneck
^Did you fix/adjust your speedometer/odometer?
Jesse James
Project "On a Dime"
Old 11-19-2008, 04:26 PM   #17
El Jay
Gone to greener pastures
My uncle says the same thing about his C-30 with the GearVendors OD.
It's probably got a lot to do with pushing a 4000 lb. sled with the aerodynamics of a barn.
But you're both saving wear & tear on your engines/drive trains.
'69 Chevy 1/2 T LWB Stepper: Daily Beater
'72 GMC 3/4 T Fleet: Another Daily Beater
'72 Plymouth Gran Coupe: ?
"Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche
"Never kick a fresh turd on a hot day." Harry S. Truman
GUN CONTROL: Never having to say, "I missed you."
Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck
El Jay is offline   Reply With Quote
Old 11-19-2008, 04:50 PM   #18
69gumby
69gumby's Avatar
I just finnished swapping out the rear end in my 69. I had 4.57 gears and found a rear end at the wrecking yard from 70 that had 3.07 gears. After cleaning and painting and installing I have come to the conclusion it would have been easier, but a little more expensive, to just go to a rear end shop and had the gears I wanted installed. While I am happy with the job I did and the way she drives I still have old used parts, if I would have gone the other way they would all be brand new.
69 sweet long fleet, David
69gumby is offline   Reply With Quote
Old 11-19-2008, 05:05 PM   #19
2bits
2bits's Avatar
[QUOTE=Tx Firefighter;2981681]Bobcat ?
QUOTE]
hmm his name is Jerrod, if that's what your asking
_______________
Thomas
'78 Silverado
'74 Monte Carlo
Old 11-19-2008, 05:58 PM   #20
Tx Firefighter
[quote=2bits;2981830]
Bobcat ?
QUOTE]
No, the welder you knucklehead . It's either a Bobcat, Trailblazer, or a Legend. I was wondering which. I'm a bobcat man myself.
Old 11-19-2008, 08:36 PM   #21
oldblue1968chevy
I dunno which gears i have
and so yall think its easier/beter spent money to take it to a rear end shop (where would i find one of those, or is that what there called lol) and have them put the gears in it id want?
and what gears would i want mostly driving around town and some 4lane highway miles...prob not alot of interestate miles though...
THANKS!
John
Old 11-19-2008, 09:15 PM   #22
BigSky71
LAIDOUT
BigSky71's Avatar
No I didn't and that is a good point, I am not counting the actual miles driven. The difference between 3.55 and 2.75 is 22.5%, hmm maybe I am getting better mileage than I thought .
So my mileage with the 2.75s is about 14 instead of 11.5. My 350 is fresh, mild cam, Edelbrock carb, headers, and a TH350, fwiw...
67 2wd Shorty
Build Pictures
Old 11-19-2008, 09:23 PM   #23
oldblue1968chevy
..so what gears are best for me...and how much $ is this gonna run..and which is gona give beter gas mileage..different tranny th350 or similar or re gear the diff. ? thanks again
John
Old 11-19-2008, 09:55 PM   #24
ratpackv8sonly
ratpackv8sonly's Avatar
New gears and a tranny. Go with a 700R4. But get someone that knows them to install the wiring for the overdrive. I know alot of people dont like them but a new reman stock Q-jet will help out with the gas milage.
ratpackv8sonly is offline   Reply With Quote
Old 11-19-2008, 10:16 PM   #25
69gumby
69gumby's Avatar
I started a thread a few days ago titled 12 bolt gear ratio. In that thread I posted some rear end ratio codes. You can find the code on the top of your passenger side axle tube. Check that out and maybe you can find out what you have now, if the gears you have now are the ones that came with your truck, then you may have an idea of where you want to go. The previous owner of my truck had installed 4.57s. My truck has a 350 / th350 and I am liking the 3.07s I just installed. I drive 75% freeway and 25% street and I have noticed an improvement in my milage right away. My truck still gets of the line pretty good but also cruses at 70 without straining.
