Old 05-12-2002, 09:11 AM   #1
BigBlock67
Post Fan and Shroud location?
Where is the proper location for the radiator fan? Should it be completely inside the shroud or should the backside of the fan be partly outside of the shroud? I've made mine flush with the shroud, but I want to make sure I'm right.
BigBlock67 is offline   Reply With Quote
Old 05-12-2002, 09:22 AM   #2
69 longhorn
Post
With a flex fan, I try to go half in/half out. If you are running a clutch fan,you might set it about 3/4 in the shroud. Good luck........69
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
Old 05-12-2002, 09:32 AM   #3
Andy4639
Old member
Andy4639's Avatar
Cool
That sounds about right, you don't want all of the mechanical fan in the shroud. It want cool as good.
Andy
71's Are for ever!!! or 67,68,69,70,72
71,factory tach,tilt for straight drive,gauges,ac,speed warning,clock,305 HO TPI with 700-R4, lowered 2" & 3" ,and 17" Chrome Stealth wheels, Pioneer reciever,100 watt amp, 6 disc changer, 2-10" subs (behind seat) 2-6x9 in doors, 2-3ways mounted under seat, and 2 tweaters on door panels
www.geocities.com/chevy71tpi/main.html
www.picturetrail.com/Andy4639
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
