Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > WIW
Old 11-19-2008, 03:53 PM   #1
MarkMark
MarkMark's Avatar
WIW A/C compressor and brackets
I'm going to be buying a Vintage Air sure fit kit, and will no longer need this setup. I'll be moving the alternator to the driver side and A/c to the passenger.
When i bought my truck the owner told me he had just bough the compressor new(refurb i assume) , and never got the custom lines made. what you guys think its worth so I can put it up for grabs?? thanks to all.
MarkMark is offline   Reply With Quote
Old 11-28-2008, 03:52 PM   #2
72armyswbtruck
72armyswbtruck's Avatar
Re: WIW A/C compressor and brackets
If those are for a Big Block (396, 400, 402) then about $125 and up for just the brackets. If they are for the 350 then $75-100.
They look like big block brackets.
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
Old 11-28-2008, 09:21 PM   #3
MarkMark
MarkMark's Avatar
yes they are BB brackets. How about the compressor?
Old 11-28-2008, 10:09 PM   #4
72armyswbtruck
Probably $75 to $100 bucks, you can pick them up on Ebay for about $125 if you watch. They are really heavy thought. And If I recall it is the same compressor.
Old 11-29-2008, 08:09 AM   #5
MarkMark
MarkMark's Avatar
cool. thanks.
Old 11-29-2008, 02:21 PM   #6
Classic Bowties
Always on the hunt...
I would also say around $75. and it should also be noted that these are for a long water pump setup (73 and up chevy trucks and 69 and up cars) only if talking oe correct.
Classic Bowties is offline   Reply With Quote
Old 11-29-2008, 08:43 PM   #7
72armyswbtruck
Good catch, those are on the drivers side.
Old 12-01-2008, 04:11 PM   #8
leddzepp
Moderator
leddzepp's Avatar
fyi...you can ship the compressor in a large flat rate box from the usps for 12.95 anywhere in the US. There is no weight limit.
leddzepp is offline   Reply With Quote
Old 12-01-2008, 05:02 PM   #9
MarkMark
MarkMark's Avatar
Thanks for that info!!
