Old 11-19-2008, 10:18 PM   #1
Chevyman680063
Chevyman680063's Avatar
Gas pedal assembly?
The gas pedal lever on my truck is loose because the bushing or whatever it is at the firewall is worn out and so the gas pedal lever slides in and out through the firewall. I was wondering is there a bushing separate from the gas pedal assembly at the firewall that holds the gas pedal lever in place or is the piece that holds it in place attached to the gas pedal assembly? Thanks for the help.
Chevyman680063 is offline   Reply With Quote
Old 11-20-2008, 11:06 AM   #2
Chevyman680063
Re: Gas pedal assembly?
Anyone?
Old 11-20-2008, 11:10 AM   #3
68gmsee
Active Member
68gmsee's Avatar
Hold on... I will take a look at mine and try to get a pic of it for you.
68gmsee is offline   Reply With Quote
Old 11-20-2008, 11:13 AM   #4
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
What year is your truck, 71-72? There are two different styles of gas pedal mounts, one like yours and the other style is two ball-mounts that are bolted to the floor. I think what you need is the assembly that bolts to the firewall. I know you're looking for a replacement bushing but I don't know of anyone selling that. You could just remove your pedal ass'y and do some of your own manufacturing to create the sleeve you need, or you could spend some bigger bucks and get Lokar's pedal ass'y. It requires a slot in the floor, and a cable ass'y to attach to your carb, but it would eliminate the worn part you showed.
Member Nr. 2770
Old 11-20-2008, 11:26 AM   #5
Chevyman680063
It's actually a '63. I figured I'd post on here because usually you get more replies and it has the same linkage as the late 60's models. Thanks for the help though.
Old 11-20-2008, 11:29 AM   #6
68gmsee
Active Member
68gmsee's Avatar
My 68 and 69 have the the same pedal asm so here's the pics from inside and outside to give you and idea.
Old 11-20-2008, 11:32 AM   #7
68gmsee
Active Member
68gmsee's Avatar
Forgot to mention,,, No bushing on the firewall on mine. Just the link.
Old 11-20-2008, 01:52 PM   #8
67mater
67mater's Avatar
i have the linkage from my 67 if you want to buy it.
time is inversely proportional to money; that's why it takes me so long
1967 K10
1967 Camaro
67mater is offline   Reply With Quote
Old 11-20-2008, 01:54 PM   #9
jephs422
Yours should only be held on by the outside bracket like in 68gmsee's pics. If your pedal isn't worn, you should just need a new bracket.
Jeff Savaglio
Scott's Hotrods
Oxnard CA 93030
jephs422 is offline   Reply With Quote
Old 11-20-2008, 05:02 PM   #10
Chevyman680063
You're right. I just took it off and the bracket that mounts to the firewall is broken on one side where it connects to the gas pedal assembly.
