Old 11-19-2008, 11:42 PM   #1
nicolas72gmc
nicolas72gmc's Avatar
4" leafs with 1-1/2" shackles.
Does anyone have actual measurements on how much drop you get with 4" springs and 1-1/2" shackles. Will it be 5 1/2" or a little less? Thanks in advance.
Nick
"Everyone has a plan, 'till they get punched in the mouth".........Mike Tyson
1968, GMC, SWB, Project
1972, GMC, LWB, Daily Driver, 383, headers, 2.5"/3" exhaust, 200r4, 3.5/5 ECE components.
1972, C/10, LWB, 350 vortec, th350
nicolas72gmc is offline   Reply With Quote
Old 11-20-2008, 12:11 PM   #2
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Re: 4" leafs with 1-1/2" shackles.
Good question, bump for the new day.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 11-20-2008, 11:44 PM   #3
nicolas72gmc
bump
Nick
Old 11-21-2008, 06:14 PM   #4
young grasshoppa
young grasshoppa's Avatar
ttt, i want to know also.
young grasshoppa is offline   Reply With Quote
Old 11-22-2008, 02:09 AM   #5
xmitsu10
xmitsu10's Avatar
No measurements but pictures. I dropped the rear with 4" drop leafs and shackles (1" or 2" positions). I could only get 1" from the shackle because the leaf made contact with the bed when in the 2" drop position. Here are some before and after pics.
71 Cheyenne SWB
xmitsu10 is offline   Reply With Quote
Old 11-22-2008, 05:12 AM   #6
slammed1
1972 Chevrolet SWB
slammed1's Avatar
since the shackle is at the very back,you generally dont get the advertised drop amount
I would say if your leafs give you the exact 4" the the shackle should get you 3/4 to an inch more.
My New thread with pics (not my build thread yet.)
http://67-72chevytrucks.com/vboard/s...46#post2573646
1972 Chevrolet 1/2 ton short wide bed,68 frt clip Project.
1980 Camaro Inherited when father passed,68K Miles
2003 Ford Mach1 FUN as Hell!!
2002 Dodge Ram 5-8 slam Rolling BillBoard (Gone not forgot)
2004 Dodge Ram HEMI 10" lifted on 37's and 2wd.
slammed1 is offline   Reply With Quote
Old 11-22-2008, 06:23 AM   #7
nicolas72gmc
Thanks guys,
that is what I will do then. I will use the 2.5" spindles, 1" front coils. In the back use the 4" leafs and 1" position on the shackles for a 3.5/5 drop.
xmitsu10 is that what you ended up doing? Yours looks just like I want mine to sit.
Nick
Old 11-22-2008, 06:39 AM   #8
slammed1
1972 Chevrolet SWB
slammed1's Avatar
please take before and after measurements so you can determine your actual drop,lots of guys dont do the initial measurement so they are guessing what drop they have.
I see it everyday,guys with a 2-4 drop claiming a 3-5 and such.....the numbers game is silly.I have actually installed an exact 2-4 kit on a guys truck and made sure the rear shackle was in the 4" setting also and not in the 4.5 setting,my before measurments and after measurements proved an exact 2-4 drop.......once he got home and placed pictures and info on his forums of choice the truck all the sudden had a 3.5- 5.5 drop.
Old 11-22-2008, 09:31 AM   #9
nicolas72gmc
yeah I agree. Mine is pretty easy, I'm setting at 32" in the front and 34" at the back. That is center of wheel opening to the ground. thanks a million.!!!
Nick
Old 11-22-2008, 02:57 PM   #10
xmitsu10
xmitsu10's Avatar
Thanks guys,
You got it right nicolas, 2.5" spindles and 1" drop spring up front. I just measured the center of the wheel opening to ground and it's 26 3/4" up front and 29" out back. Tires are 255/60/15 front and 275/60/15 rear so the front tire aspect ratio is lower than the rear. It's about 22 degrees outside now so I am sure my tire pressure is a little lower than it should be today, hence it may be sitting lower a bit than it normally would. Sorry I wasn't smart enough to take the same measurements before I dropped it last year.
Mark
71 Cheyenne SWB
Old 11-22-2008, 11:09 PM   #11
nicolas72gmc
thanks Mark. I will let you know what I end up with when it is done. 22 degrees!! no thanks. It is @ 65 here now. Thanks for all of your help.
Nick
Nick
