Old 11-20-2008, 02:06 AM   #1
69step4x4
69step4x4's Avatar
Cab Rottisurri ?
I see a post on here before someone had a cab mounted to a mount where you can roll the cab on to its back to work on bottom,, does anyone know how to locate that post?
Thank You
Lowered 2002 PT Cruiser ONLY for mileage.
1969 Stepside 4x4 ( under construction )
69step4x4 is offline   Reply With Quote
Old 11-20-2008, 10:44 AM   #2
jorgensensc
jorgensensc's Avatar
Re: Cab Rottisurri ?
It is the Tip and Flip! I know Mikes Bump and Grind Garage sells the instructions for it. A member on here came up with it, and I Think he still sells the instructions himself too.
Shawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 11-20-2008, 10:51 AM   #3
sick69
sick69's Avatar
Member Rokcrln was the designer and yes he does sell them himself. A killer design.
A couple other rmembers came up with great designs aswell.
I'm sure they will chime in.
Frank
70 chevy lwb c10
454/th400 and a 9" rearend
suicide doors, marker light fuel fill, 4" cowl , mini tub
sick69 is offline   Reply With Quote
Old 11-20-2008, 05:43 PM   #4
69step4x4
69step4x4's Avatar
Thanks Guys, I got all the info i needed.
