11-20-2008, 02:18 PM | #1 |
bolts/studs for s/b factory A/C
These are the bolts that I have to install the 7 piece style factory A/C brackets to the cast iron stock exaust manifolds on a small block. Do I have the correct bolts/studs for this application? I can measure and give exact dimensions if needed.
Don't tell me what you're gonna do...SHOW me what you've DONE!!! Click here for the TRUTH... Last edited by clean cut creations; 11-20-2008 at 02:19 PM. |
11-22-2008, 07:53 PM | #3 |
Re: bolts/studs for s/b factory A/C
Is truck a 4x4? The stud on far right resembles the stud used to hold 4x4 dipstick in place. If not 4x4, the stud is the one located in the water pump for the frant most bracket. The correct studs are the hard pieces to get, the rest is available in the aftermarket. But to answer your question, yes it looks like you have what you need. Harold
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
11-23-2008, 11:17 AM | #4 |
Thanks Harold! These are all exaust manifold bolts, including the right one, and that SHOULD be for a dipstick retainer. The truck these came from is a 2WD but the previous owner installed drivetrain and several options like factory AC from another truck...POSSIBLY a 4x4? The truck was just missing some important AC brackets and we got that squared away with the help of another post. I just couldn't get info on proper bolts and I didn't want to trust the previous owners building skills! Thanks for the info!!!!
Don't tell me what you're gonna do...SHOW me what you've DONE!!! Click here for the TRUTH... |
