Old 11-20-2008, 05:04 PM   #1
Effle18
Inexpensive gas tank for a 56?
I would like to relocate my tank to under the bed of my 56, but the gas tank I keep finding on the internet will be about $450 shipped with everything (straps, sending unit etc.) does anyone know of a cheaper option?
96 Bagged 2Door Tahoe
69 Blazer
Effle18 is offline   Reply With Quote
Old 11-20-2008, 06:55 PM   #2
robin58
Re: Inexpensive gas tank for a 56?
Look at some S10 Blazer tanks. They should fit behind the axle.
robin58 is offline   Reply With Quote
Old 11-20-2008, 08:29 PM   #3
bfink
i put a pro-street fuel cell from summit racing under the bed of my 55 . Its 16 gal , 25"x17"x9" , comes with a 0-90 ohm GM sending unit in the tank and runs about $ 145.00 . All you have to do is drill out the rivets and move the rear frame brace back a few inches and it drops right between that and brace where your shocks mount . i also got the straps from summit they were 30 bucks and 12.75 to ship it all
FINK
bfink is offline   Reply With Quote
Old 11-20-2008, 08:32 PM   #4
dieseldr4
i just did a low dollar build on a 57 , i used a tank out of an early 80's pontiac grand prix.. most a or g boy tanks from that era should work.. ours was a regular leaf spring set up and with the roll pan on and the truck at ride hieght you cant even see it.. its around a 15 gallon tank.. hope this helps you..
dieseldr4 is offline   Reply With Quote
Old 11-20-2008, 08:33 PM   #5
dieseldr4
i just did a low dollar build on a 57 , i used a tank out of an early 80's pontiac grand prix.. most a or g body tanks from that era should work.. ours was a regular leaf spring set up and with the roll pan on and the truck at ride hieght you cant even see it.. its around a 15 gallon tank.. hope this helps you..
Old 11-20-2008, 09:30 PM   #6
Gene Sharp
used gas tank from a 73 - 86 Big Blazer
used cross members and Straps
Drilled a hole in recessed circle on top of tankand installed early gauage
Fuel guage works well and every thing looks good
Fill in bed of truck
Gene Sharp
Gene Sharp is offline   Reply With Quote
Old 11-21-2008, 12:00 AM   #7
entourageguy
Yellow truck club
entourageguy's Avatar
same type of summit tank
Name:  rear frame 3-1.jpg
Name:  fuel filler gate down-1.jpg
Brian ......
My hub garage address
http://www.hubgarage.com/mygarage/59apache
I gue$$ everything has it'$ price
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
350 700r lokar shifter
power MII front end, shockwaves
tilt, 4 wheel discs
4-link and bags
10 bolt limited
entourageguy is offline   Reply With Quote
Old 11-21-2008, 10:11 AM   #8
Effle18
Thanks for all of the help, I am going to try and track down the summit tank it looks perfect...if not, junk yards here I come..
69 Blazer
Old 11-21-2008, 10:23 AM   #9
Houston54
One thing you need to keep in mind when picking a tank is whether it will give you enough room on the sides to route your pipes. If you are not taking them out the back this may not be a problem but if you are going over the axle you will need to have at least three inches between the leaf springs and the tank, preferrable four inches.
I was using an 18 gallon 1st Gen camaro tank when I realized this was a problem and went with a Tanks, Inc universal truck tank instead. I lost a couple of gallons of capacity but it was an easy install and provides plenty of room for the pipes. The cost was about $210.00 with free shipping. They also can provide some tank straps but these can also be made easily from 1" x 1/8 flat bar available from Sears hardware or Ace or any of the big box stores.
Houston54 is offline   Reply With Quote
