Old 11-20-2008, 06:44 PM   #1
d10s69c10
Built 4 Speed
d10s69c10's Avatar
12 Bolt has got me Ticked.
Well as last week i had thrown My drive shaft burning out. I accepted that and it is at a local 18wheeler shop getting beefed up.. NOW for the new issue i looked at my rear end today and noticed a Good dent pointing outwards. After about 10 minutes of disbelief i ripped off the cover and wallaH my spider gears are sitting in the bottom of the diff. All this stuff is BRAND NEW!!i got it to where im gonna blame one in particular it seems to be broken perfect in 3 pieces, Ring and pinion are fine so im gonna shove a locker in now..
Quesion: whats the deal with C Clip Disconnects for installing a locker. Last time i was gonna put one in Advanced driveline said it would cost about a GRAND to put a locker in this sound right?
or should i start looking for a 9"...
1969 C/10 Short Box:
496/T-56 in worx.
"To Be Old And Wise, First You Must Be Young And Stupid"
d10s69c10 is offline   Reply With Quote
Old 11-20-2008, 07:55 PM   #2
cdowns
cdowns's Avatar
Re: 12 Bolt has got me Ticked.
a thousand is about the price of getting a posi rear setup yes
Old 11-20-2008, 08:42 PM   #3
corn
12 bolt/tough dif=yes
12 bolt/indestructible=nope
My buddy is running a spool in his 12 bolt truck & hates it. I suggest buying a good aftermarket unit unless its drag race only.
corn is offline   Reply With Quote
Old 11-20-2008, 09:56 PM   #4
d10s69c10
Built 4 Speed
d10s69c10's Avatar
i agree with the indestructable part i know.
1000.whew
i dont know this new diff only lasted maybe 1500 miles. maybe im a bit 2 hard on it.
any other rear ends people run thats pretty tuff and readyily available?
496/T-56 in worx.
Old 11-20-2008, 11:57 PM   #5
cdowns
cdowns's Avatar
9"rears are readily available and easily converted to these trucks or if you really want bullitproff google up mark williams he can build you up a really stout rear for a bit less than 10grand
Old 11-21-2008, 01:33 AM   #6
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
build a Dana 60.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 11-25-2008, 02:29 PM   #7
d10s69c10
Built 4 Speed
d10s69c10's Avatar
http://www.carcraft.com/techarticles...ord/index.html
found somthing kinda interesting still contemplating.... i have found a whole new 12 bolt and drive shaft and also a 9 inch no luck on a dana 60 tho..
496/T-56 in worx.
Old 11-25-2008, 02:55 PM   #8
justcuz
justcuz's Avatar
How about a semi-float 14 bolt? They are just about as strong as a dana 60.
GM used them in a lot of applications, 454SS, TrailblazerSS, some Z71's and light duty 2500 pickups. Alot of them were in 3/4 ton pickups of the eighties and 5 or 6 lug axles/drums/brakes can be found for them. They are big, with a 9.5 inch ring gear. Get one with an open driveline and install a Loc Rite in it. You can find Loc Rite's on sale occaisionally for around 200 bucks. I paid 135 dollars for my last 14 bolt SF at the local P&P. For less than 500 bucks if you handy you can have a tough rear axle.
justcuz is offline   Reply With Quote
Old 11-26-2008, 01:05 AM   #9
Ford Assassin
Ford Assassin's Avatar
I looked into this option, but how to mount it in a trailing arm truck?
Cable
-K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt
-Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608
Ford Assassin is offline   Reply With Quote
Old 11-26-2008, 08:42 AM   #10
bigsnookmaster
bigsnookmaster's Avatar
As much as I hate to admit it,The 9" F rearend is hard to beat.Tough as nails and it's real easy to change center chunks if needed.
bigsnookmaster is offline   Reply With Quote
Old 11-26-2008, 11:52 PM   #11
justcuz
justcuz's Avatar
Trailing arm saddle brackets are sold by several speed shops around the country. You can find them oneline pretty easy.
Old 11-27-2008, 01:22 AM   #12
Ford Assassin
You would be doing me a great favor if you could list any online vendor(s) of such pieces.
Cable
Old 11-27-2008, 12:09 PM   #13
d10s69c10
Built 4 Speed
d10s69c10's Avatar
Well im not sure about the vendors but generally ill just set small pieces like 1/4 of stock (Already drilled) on my arms place axle over them measure every wich way then tack up my pieces and build around it.
Around here its pretty common to do. but make them welds hot and deep.
496/T-56 in worx.
Old 11-27-2008, 12:43 PM   #14
Boog
laying low
Boog's Avatar
New axle saddles are available from several suspension vendors. Not expensive and I'd check with one of our board vendor first. I'm pretty sure ECE has them.
You can always torch off your old saddles and weld them to the new rear end.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 11-27-2008, 05:11 PM   #15
Ont67shortbox
DTS (no I don"t work there) has a BOLT IN 9 inch/Dana or 12 bolt for our trucks complete or just housing and axles. They used a DTS rear on Project Copperhead, thats how I remembered. I think I am going to order one from them.
Ont67shortbox is offline   Reply With Quote
