Grease Monkey
Picked up a Dana 70HD and pic update
My buddy had this Dana 70HD laying in his backyard and said I could have it. Took the cover off and found 3.73 gears and factory posi. I did a brake job, added a chrome diff cover, painted it and called it good.
![]() ![]() I plan on doing a disc conversion of it. I'll make sure to make a DIY thread when I get around to it. Here are a few updated pics of how the truck sits a year after the build. Hopefully I'll be able to finish the body work soon so I can get it painted. ![]() ![]() ![]() ![]() ![]() ![]() ![]()
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053 Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12 |
Between Trucks...
Re: Picked up a Dana 70HD and pic update
That's a sick rig. What color are you going to paint it?
Beat it to fit, Paint it to match... ![]() |
Watch out for your cornhole !
![]() Join Date: Jun 2003
I'm running a Mag-Hytec aluminum cover on my Dana 70. You might check them out, they add a lot more fluid capacity, have a built in dipstick and a large magnet to catch the metal floating around in the oil.
Grease Monkey
its going to be a med to dark blue
that truck is awesome
![]() what size is your lift, and how big are the tires?
Trial and Error, its expensive but its a mistake i most likely wont make again 1971 chevy k10 custom deluxe http://67-72chevytrucks.com/vboard/s...d.php?t=341257 1968 chevy k/10 fleet http://67-72chevytrucks.com/vboard/s...d.php?t=334731 1948 desoto custom coupe fluid drive(family heirloom) |
6>8 Plugless........
![]() Join Date: Sep 2007
That is a nice truck! It will look awesome when painted!
Grease Monkey
Its a custom 12" lift with 39.5 IROKs on 17" M/T wheels
Is that an air quick coupler sitting on the axel?
Its hard to make out in the pic. Some kind of "one off" custom streemlined axel vent Nice truck, getcolor ![]() chas
"I'll Procrastinate Tomorrow" quote by LEEVON 71 K10 long fleet (sons truck) new 370hp 355, sm465 np205, 3.73's 33's 70 K20 long fleet 98 G3500 work van |
Grease Monkey
Yes its an coupler. It threw me when I first saw it. I thought it might have a air locker. It just a breather. Which is what I am trying to figure it out need for both axles. cleanest route for breather hoses.
are you keeping the 3.73s in it when you install it??
seems a little high for 39.5s
RN U OVR Last edited by Senator350; 11-21-2008 at 08:19 PM. |
It looks like to me that the D70HD is in the truck in his pictures. Or it is a D60.
yeah.. you're right. hard to tell the 60 from the 70 without a tape measure. i noticed the same air vent breather after i posted :doh:
i'm pretty sure i recall reading/hearing about alternative axle vents like your air coupler before. the set-up you have will allow you to just put the breather hose on IF and when you cross water. doubt that truck sees much time off road tho...
RN U OVR |
#13 | |
Grease Monkey
#14 | |
that would be the shiz! i always regret not getting pictures of my last truck when it was built and covered in mud ![]() I'll have to check the gearing in my 70HD. If I have 411s or 456, maybe you and I can trade! I'd rather have the higher gears now that mine will be pretty dedicated to the streets.
RN U OVR |
#15 | |
Grease Monkey
do you have a locker or posi?
