Old 11-20-2008, 10:51 PM   #1
jholley
jholley's Avatar
Cab Cart
Anybody here ever built a stand to mount your cab to work on out of an old chassis? I have a bent one that I have to get rid of anyway. I'm thinking about cutting it in front of and behind the cab, welding on some legs and wheels and braces and viola a cab stand. Thoughts?
Jim
Garage fillers...
85 Chevy C10 Silverado LWB
07 Nissan Altima
2006 Mini Cooper S
jholley is offline   Reply With Quote
Old 11-20-2008, 10:57 PM   #2
Richard8971
Still livin the "dream" in '54
Richard8971's Avatar
Re: Cab Cart
Sounds like a pretty awesome idea to me.
D
Current build. 1954 Chevrolet 3800 "Ella" SOLD!
My '67 stepper "Tangerine Dream"
"Anything worth doing is worth doing right" James Dean
“When you have eliminated all which is impossible, then whatever remains, however improbable, must be the truth.”
Sherlock Holmes
"There is no spoon." Neo
Richard8971 is offline   Reply With Quote
Old 11-20-2008, 11:11 PM   #3
chas350
Re: Cab Cart
http://www.sierrasolutions.biz/body_buggy.html
I think I may build something like this, its adjustable, for the cab and bed.
But I am going to use large pheumatic casters so I can wheel it outside on the driveway.
chas
"I'll Procrastinate Tomorrow"
quote by LEEVON
71 K10 long fleet (sons truck) new 370hp 355, sm465 np205, 3.73's 33's
70 K20 long fleet
98 G3500 work van
chas350 is offline   Reply With Quote
Old 11-20-2008, 11:32 PM   #4
Ricks1971
Ricks1971's Avatar
Re: Cab Cart
I thought of doing the same thing awhile ago. Then I saw this post about a dolley on the boards here. For the amount of time I'm building one of these dolleys.
http://67-72chevytrucks.com/vboard/s...06#post1941906
Ricks1971 is offline   Reply With Quote
Old 11-20-2008, 11:46 PM   #5
lpaine
lpaine's Avatar
Re: Cab Cart
I've got the frame section from a parts truck sitting in my shop, (leaning against the wall!) , I was going to put 4 heavy swivelling castors under it for moving the cab around,(for my '67) just haven't had/made the time to do that, my only concern with that plan is that it is going to put the cab low to the ground and make it difficult to work under the cab if needed.I might make the frame section/castors higher when I finally get it together.Or I could possibly make the cart/dolly "tiltable" to be able to flip the cab on it's back if needed. I beleive rocklyn or maybe glock35spc have done a tilting cab dolly arrangment, with plans for making one.I'm sure someone else will chime in on this if I'm wrong.
1969 G.M.C 3/4 Ton 920 (Canadian Version) 307 3 speed, currently apart
1998 Chevy 1/2 ton ex cab V-6 5 speed
1967 Chevy SWB - project truck; not started just yet
lpaine is offline   Reply With Quote
Old 11-20-2008, 11:59 PM   #6
chas350
Re: Cab Cart
lpaine, sounds like it would be REAL heavy. But hey the steel is free, right?
chas
quote by LEEVON
70 K20 long fleet
98 G3500 work van
Old 11-21-2008, 12:14 AM   #7
Aarons72s
Re: Cab Cart
Here is how I built a small one to temporarilly make the cab mobile. I cut the original front and rear of the frame off with the cab still atached. But first I drilled and bolted heavy duty casters to the frame in all four corners. The best place to cut the frame at the rear is just after the main crossmember. As for the front I just cut it where it would fit in the garage. You will have tto use and leave installed a auttomatic transmission crossmember. Or you could weld in a piece of steel instead. I thought about makeing it taller later but instead was given a cab dolly from the widow of a truck I built. I hope these pics will give you some ideas. If you want to see they dolly that I curently use just click on the link in my sig for the 67 swb build. I wish I had better pics but this all I have. I scraped the temp one after getting the new dolly.
Aarons72s is offline   Reply With Quote
