Fan Squeels
almost everytime i turn my heater fan on it squeels pretty loud and will slowly quiet down, and it will do this at any speed. but if i were to turn it off for a little then on it will turn on with no squeeling. im guessing my fan is reaching the end of its life span, it has been doing this for quite a while now.
eh ![]() 1970 Chevy C20 daily driver ![]() 1975 GMC Jimmy 4x4 project ![]() 1966 GMC C10 Dad's project ![]() |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Re: Fan Squeels
Take the motor off and lay it on the workbench. Drill a tiny hole in the bump on the housing right over then end of the motor shaft and dribble thin oil into the hole. This will lubricate the dry bushing and stop the squeel. Cover the hole with a dab of silicone when finished.
I am a Referee of life.
Re: Fan Squeels
I did that,but did it in place and it worked well.I relubed it every year for about 3 years.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
Re: Fan Squeels
That will work if the bushing is not already destroyed. My fan shaft wobbled a lot when I pulled it out.
For me, if I am going to the trouble of removing the fan completely, I will replace it no matter what. The fan motor is only about $20 at AutoZone. The part number is PM-102. This motor moves more air than the old motor did in 12 years. http://www.67-72chevytrucks.com/vboa...t=Blower+motor
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
Re: Fan Squeels
I forgot to add, when you pull the blower motor, reach in the hole as far as you can and pull out the crap. Leaves,seeds and other junk could be blocking the passage. I connected (ain't duck tape great?) a tiny vac hose onto my shop vac and wiggled it all around in there. Plug the hose twice. Could part of the reason I have way more air flow. The heater will melt you in the dead of winter.
