11-21-2008, 12:18 AM | #1 |
67-72
a little air ride help.
I was just wondering what to get for a compressor or compressors. I will have a 12gal air tank and 3/8 line. im not looking to go up and down alot but i just dont want a compressor running all the time. im not sure what i should go with i was looking at getting the combo pack of viair 480s or 380s any help... thanks alot Jake
11-21-2008, 01:58 AM | #2 |
Re: a little air ride help.
Check out the compressor calculator. It'll give you good estimates on fill times.
http://www.airridetalk.com/calculators.html |
11-21-2008, 02:24 AM | #3 |
With that large of a tank I would run at least a 480 dual pack. Its a nice compressor, you won't be disappointed.
If you can find it cheaper, I can fix it! |
11-21-2008, 02:43 PM | #4 |
480s ftw i have one 480 i rebuilt on a 7 gallon and at 150 psi and the refill time is quick but im not switch happy but when i am i run nitro
http://img.photobucket.com/albums/v5...ropped/sig.jpg |
11-23-2008, 01:21 AM | #5 |
Stirrer of the Pot
Have you considered an EDC? for a 12 gallon tank you might give it some thought...
I run 400C's on my 9 gallon tank and they fill pretty fast, but they are limited in max PSI (rated at 145psi, but I have a 175 pressure switch.... ) I am putting 380C's on my truck (actually, they are already installed) and they are rated at 200PSI with 100% duty cycle. I realize you don't *want* them running all the time, but if you go with electric, and a 12 gallon tank, they will fill a little slower anyways. You can get a York EDC installed for a few hundred bucks. |
