Old 11-21-2008, 01:15 PM   #1
wedgemon
wedgemon's Avatar
Cool 454 to Crate 350 Swap
OK, after 4 attempts at getting his 79 K10 454 to pass smog. My kid has decided he's going to get a GMPP Crate Engine. (Summit is in town and is an easy pick up.) We need to figure out what he needs to accomplish this swap.
We have the following to fit a 350:
*Edelbrock intake
*Edel 1406 Carb
*Factory cast exhaust Manifolds
*Alternator
We will need:
*Waterpump
*Dizzy
We'd like to know if we can use these from the 454:
*Flex Plate
*Starter
*Existing engine wiring
*Throttle and TV cables
*Senders & Switches
*Power Steering pump
*Crank pulley
What did we miss?? And cautions or warnings. Other than coming up with a parts list, it seems pretty straight forward.
The 454 was squeezed in by a P/O. The boy plans to re-sell it. Head work needed.
I trust you guys will not send us astray!!
- Dave
2003 Silverado K1500 Z71 - Arrival Blue
1973 K5 Cheyenne Blazer 350/TH350/NP203
Kids Trucks:92 K1500 Blazer 5.7/700R4 4" lift.
RETIRED: 1980 Scottsdale 4x4
Founding Member:
"TILT WHEEL BELLY." Club
wedgemon is offline   Reply With Quote
Old 11-21-2008, 01:24 PM   #2
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Re: 454 to Crate 350 Swap
*Edelbrock intake
*Edel 1406 Carb
*Alternator
*Dizzy - THIS is the same you dont need a new one.
We will need:
*Waterpump
*Flex Plate - NO
*Starter - Yes - (depending on the flexplate you get must be same tooth count)
*Existing engine wiring - Yes
*Throttle and TV cables - Yes
*Senders & Switches - Yes
*Power Steering pump - Yes
*Crank pulley - No
What did we miss??
Any accessory brackets for alt, AC.
Exhaust will be different most likely
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 11-21-2008, 01:35 PM   #3
Twisted78SS
Wide n'Low
Twisted78SS's Avatar
When you say gm crate, it makes thing that it will have vortec heads, is your manifold for the vortec heads?
Otherwise it looks like your fairly set.
Trippin Hazard.. 67 swb,
Gold Member.. 68 Suburban
Air Force Retired
Twisted78SS is offline   Reply With Quote
Old 11-21-2008, 02:35 PM   #4
Pyrotechnic
Pyrotechnic's Avatar
If the goal here is simply passing smog, you need to give us more info. Here in Texas, 1983 and under is exempt completely.
First of all, what are the smog laws in that area ? Usually smog checks consist of visual inspection, meaning, is ALL of the factory emissions equipment in place and working ? AIR, EGR, catalytic converter(s), etc. The other half is tailpipe emissions, which is analysis of the exhaust gases coming out of your tailpipe.
Which ones are you subject to ? It's a good idea to read up on the laws directly from the DMV. I've had some inspection technicians on a power trip fail me for an open element air cleaner, even though at the time my truck was exempt from emissions completely and should have passed. Know your laws.
Which ones are you failing ?
If it is the visual you are failing, the new crate motor will fail you as well. If it's tail pipe you are failing but you have everything in place, you need to look into what is failing it.
If you are failing visual, the best idea might be to do a late model fuel injection swap. A 5.3 or 6.0 with matching transmission and computer would make great power, get great gas mileage, and pass emissions with flying colors. Usually the truck gets inspected as if it were the vehicle the motor came out of.
The only way I can see that the crate 350 will work for you, is if visual inspection does not matter, but they want tail pipe emissions. Keep in mind, you WILL need catalytic converters, and the carb and timing will need to be spot on.
Sorry to sound so cautious here, but I hate to see someone spend so much money to pass the emissions game but still fail it despite a brand new motor. Let us know what you are up against.
1977 GMC Sierra Grande
Pyrotechnic is offline   Reply With Quote
Old 11-21-2008, 02:52 PM   #5
454HO
What needs head work? The engine, or the boy for selling the engine?
Like Pyro says, why are you failing smog test? Maybe there is an easier less expensive solution you have overlooked.
- Greg
454HO is offline   Reply With Quote
Old 11-21-2008, 05:29 PM   #6
wedgemon
wedgemon's Avatar
Pyro & 454 -
Smog in Washoe County, NV for 1980 and earlier, requires a visual on the gas cap gasket only - call that semi-exempt. BUT, it must pass the sniffer. And it's high on CO and HC at low idle. We had it to a smog analyst shop last week and he did a side to side check and discovered the passenger side is way off the charts and the drivers side is within legal requirements. We do have a knock/tap in the right head. Won't adjust out. So, bad seating, bent valve or pushrod. In any case it needs work.
Now, to the boys' head... He's living at home, gets a decent paycheck and is getting $2500.00 from me next week. So, instant gratification 19 year old wants a crate engine.
In the long run, it's probably best. As he wants some warranty and dependability. Not to mention the back up of his 350 savvy Pop! Plus, he's only put about 300 miles on it and filled up twice. 454 collness fator versus 350 economy. Guess which wins.
I might consider the 454 of my 73 Blazer or my 80 K10. I tow horses and a travel trailer
occasionally.
Thanks for the advice.
- Dave
Founding Member:
Old 11-21-2008, 06:05 PM   #7
sdavid
sdavid's Avatar
You will probably need a fuel pump also. Belts, radiator hoses, things like that. Quite a few crate motors come with a water pump installed and flexplates, so check that before you buy one. Motor mounts should work also.
'81 C10 Stepside, SBC, T350, Wood Bed, and silverado options
'87 K5 402 BBC, T350, 3.73s locked up, 2.5"Lift, 33x12.50x15s
sdavid is offline   Reply With Quote
Old 11-21-2008, 06:42 PM   #8
wedgemon
wedgemon's Avatar
One more thing...
TH350 should be OK, right?
- Dave
Founding Member:
Old 11-21-2008, 06:43 PM   #9
arkracing
Weekend Warrior
The power steering pump won't fit unless you change the brackets over to Small Block ones - which requires pulling the pulley.
Everything else mentioned looks good.
-'07 GMC Sierra K2500HD
-'66 C10 Suburban
-'68/'71 K20 Service Bed Project
-'69 Chevy C30 Mason Dump
-'33Ford P/U 396ChevyPowered
arkracing is offline   Reply With Quote
Old 11-21-2008, 09:27 PM   #10
Thumpin455
My truck is an alcoholic
Thumpin455's Avatar
TH350 should work no problem and live a bit longer.
If you cant get it to pass sniffer with the Edelbrock carb, I can set you up with a Qjet that will run rings around the E-carb. I am rather fond of my cores, so you would be better off finding one if you want one done. Just no Edlebrock Qjets, and no rebuilders, they are usually screwed up pretty bad right out of the box. The E is ok, but calibrations are a bit out there most times.
They arent that difficult, its just more adjustability than most people care to deal with, or they just dont know about Qjets.
PM if interested, maybe we can trade something.
Too much stuff, too many projects to list everything.
my 454 urged 76 swb beater
Thumpin455 is offline   Reply With Quote
