Old 11-21-2008, 02:01 PM   #1
duceducenine
duceducenine's Avatar
22 X 9.5 with 5" bs front and rear?
im looking at some 22 X9.5 torq thrust m's w/ 6.5 bs with ford 5 on 4.5 pattern to put on my 72 c10....i need 1.5 wheel adapters which will push the rims out to the 5" bs i listed but i am not sure about the fitment on the front fenders....im thinking of putting these on 255 30 22 tires?
ANY HELP WILL HELP
duceducenine is offline   Reply With Quote
Old 11-22-2008, 12:03 AM   #2
gringoloco
A guy with a truck
gringoloco's Avatar
Re: 22 X 9.5 with 5" bs front and rear?
How low are you? Should be about perfect out back. 5" would work for an 8.5 up front- you can get adapters 1" thick which would give you 5.5...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 11-22-2008, 04:03 AM   #3
duceducenine
would i have to cut my og studs ?
Old 11-22-2008, 11:30 PM   #4
gringoloco
A guy with a truck
gringoloco's Avatar
Depends on how the back of the wheels are shaped. If the mounting surface is flat, you may need to do some grinding. If there are 'reliefs', you may be OK...
-Chris
Old 11-25-2008, 12:15 PM   #5
duceducenine
thanks gringoloco
hope to post if i get them...... done
