Old 11-21-2008, 08:36 PM   #1
50adrod
50adrod's Avatar
rim and tire combo for front
I have a mustang II suspension on my 1950 and am looking for tire/rim sizes. I want to fill the wheel well as much as possible. I am going with 17X10 inch rims on the rear with 285/40 tires. I want 17's on the front also. let me know what you have and pics would be good also. thanks
1971 Corvette convertible 454@ 525 hp
1936 Chevy Truck street rod
1952 Chevy truck hot rod build http://www.killbillet.com/showthread...2-Chevy-Cut-up
1964 F 100 custom street rod http://www.ford-trucks.com/forums/12...mark-viii.html
1950 custom Chevy Truck
50adrod is offline   Reply With Quote
Old 11-23-2008, 09:16 PM   #2
50adrod
50adrod's Avatar
Re: rim and tire combo for front
nobody using the mustang II suspension ??? I was thinking maybe 17x8 on the front
Old 11-23-2008, 09:27 PM   #3
71'tahoe
71'tahoe's Avatar
I would say that a 17x8 in the front with around a 4"-4.5" back spacing would work with around a 245-45 tire. that way your overall tire hieght is close to the same. Maybe try a 235-45 but they get a little harder to find.Do you have a certain brand tire you want to use? Give me a few names and I will get you some answers on tires. Ill look into the front wheels size also.
71'tahoe is offline   Reply With Quote
Old 11-23-2008, 10:41 PM   #4
50adrod
50adrod's Avatar
the tire brand is not important to me, I am going with Boyd Smoothie II rims, they are custom order and the minimum backspace is 4.5"
pic of rims
http://www.buyboydwheels.com/smoothieII.php
Old 11-24-2008, 02:34 AM   #5
cajundragger
depends how low you want to go.
Im laid on the running board with 20x8 and 255/35/20. I have like ~5.5 of backspacing so I can turn alot when reallly low.
cajundragger is offline   Reply With Quote
Old 11-24-2008, 08:26 AM   #6
50adrod
50adrod's Avatar
mine is not going that low it is lowered 5" in the rear and using stock M II spindles up front. it will sit at this level
theese are 17x8's from my vette. the bolt pattern is different so the fronts are up against the wheel studs. it would go in another inch or so.
Old 11-24-2008, 09:20 AM   #7
1sik52
If you want to fill your wheel wells at that ride height I would suggest in going with a 20 up front and a 22 in the rear. That will set that truck off!
1sik52 is offline   Reply With Quote
