11-22-2008, 01:19 AM | #1 |
Disk Brake swap question Master cylinder?
My buddy just picked up a 70 shortbed GMC, it had 4 wheel drum brakes. I helped him add the ECE disk brake spindles, rotors, and calipers kit. We have the lines bled correctly but the pedal still goes all the way to the floor, I can see the calipers grabbing the rotor though. Do I need to swap master cylinders?
'71 Chevy 3/4 Ton Longbed '22 Chevy Tahoe RST '67 Firebird- 8 sec street car '24 GMC CC 4x4 Duramax Dually |
11-23-2008, 02:17 AM | #2 |
Re: Disk Brake swap question Master cylinder?
C'mon atleast somebody tell me that they are the same M/C and I'm just not that bright....
11-23-2008, 02:52 AM | #3 |
Retired Air Force Veteran
Yes you do need to change the Master Cylinder. You also have to use a proportional valve. I just bought a new Bendix Master Cylinder from Advanced Auto for $57.00 There house brand is $39.00 for a new and $19.00 for a reman plus core. Go with a new one.
Harry 69' SWB Step Side 1/2 Ton w/68' Front Clip Swap from Leafs to Trailing Arms (Complete) Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front) 3/6 Drop Help Support The Board Click Here For Information On How To Subscribe Krue's FAQ Page Vendors Last edited by myoldchevytruck; 11-23-2008 at 02:53 AM. |
11-23-2008, 09:51 AM | #4 |
Junior Member
My ECE kit came with a new M/C and prop valve.
63 C10 70 Coronet R/T 67 C10 70 Dart Swinger 71 K10 |
11-23-2008, 10:33 AM | #5 |
What was the price of that ECE kit and what's included? Thanks.
Harry 69' SWB Step Side 1/2 Ton w/68' Front Clip Swap from Leafs to Trailing Arms (Complete) Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front) 3/6 Drop Help Support The Board Click Here For Information On How To Subscribe Krue's FAQ Page Vendors |
11-23-2008, 02:23 PM | #6 |
Junior Member
It wasn't cheap. But, high quality stuff. I can't remember the exact price, I also bought a lowering kit. I think the link is www.earlyclassic.com can't seem to find my catalog right now.
11-23-2008, 03:58 PM | #7 | |
Next project: 1970 K10
The "distribution valve" on the drum/drum set-up does just, distribute fluid equally to all four wheel cylinders. On a disc/drum set-up, the "proportioning valve" distributes the fluid in different proportions to the front (disc) and rear (drum). Some are even adjustable to get the right amount of grab front and rear.
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
11-24-2008, 01:56 AM | #8 |
Glock is right. Drum m/c for drum brakes and Disc m/c for disc brakes. You'll need that prop valve too.
shade tree mechanic, 68 chev stepside, 350 w turbo 400 & GMC front clip, Factory Five Cobra, 29 model A with 289 w C-4, 68 Barracuda Fastback w/360 |
11-24-2008, 03:05 AM | #9 |
THE DAMN YANKEE
not only do you need a prop valve but ,i believe the reason why you have no pedal is because you may have neglected to bleed the master cylander. also i'm almost positive the piston bore in the M/C is a larger bore size for disc brakes
11-24-2008, 03:24 AM | #10 |
My disc/drum setup works well with the stock drum/drum MC, but now I am worried. I'll just keep an eye on it.
