Old 11-22-2008, 11:47 AM   #1
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Watts link rear set-up
I have been looking at getting one of these so I can get my truck on the road as the wanted modifications seem to never end and at this rate im never gonna drive it agian. So whats the pro's and con's of a watts link set-up. Any pointers on setting it up. My frame is already notched and boxed so I believe it is ready to go I just wanna do some homework before I jump in..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 11-22-2008, 12:16 PM   #2
Slmd92DIME
Slmd92DIME's Avatar
Re: Watts link rear set-up
The bars need to be horizontel with the ground at ride height. When the truck is totally aired out the the centerlink should be just slightly off centered. There was a read up of suspensions in street trucks and it told you everything about each different set up. Here is mine.
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=269019
Petitioning *No Regrets* MD/WV
Slmd92DIME is offline   Reply With Quote
Old 11-22-2008, 12:36 PM   #3
FRENCHBLUE72
PROJECT 7DEUCE
Is that a kit you bought or is that home made?
MEMBER #6377
Project "7DEUCE"
Old 11-22-2008, 02:11 PM   #4
lowestsixty7
We did this watts link about 6 years ago.
lowestsixty7 is offline   Reply With Quote
Old 11-22-2008, 06:30 PM   #5
Slmd92DIME
Slmd92DIME's Avatar
I bought the kit from speedway but only ended up using the bars. Which I stilll had to cut down and retap them. So I pretty much wasted that 60 bucks on their kit. I made everything out of some thick flat strap, a suicide doors bushing and bung, and some box tubing.
My Build Thread
Old 11-22-2008, 11:37 PM   #6
gringoloco
A guy with a truck
gringoloco's Avatar
I've read that the optimal set-up is to have the outer links on the axle and the pivot point on the frame. Seems like it would be easy to do by building a crossmember behind the axle- but I've never seen one done that way...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 11-23-2008, 12:49 AM   #7
Big H
Big H's Avatar
It's designed to be set up just like that. In a performance application with heavy cornering, like a track car, the watt's link creates equal left and right cornering controls at the roll center when then pivot is located on the frame. When the pivot is located on the axle, like in the above images, the roll center of the vehicle changes as the axle moves up and down and creates differing cornering forces at different drive heights. For an air suspended truck that isn't seeing major cornering then it's really not much of an issue. There's "perfect world" and then there's an okay compromise. Mounting the pivot on the axle in airbagged trucks is an okay compromise.
Cleverly disguised as a responsible adult...
Big H is offline   Reply With Quote
Old 11-24-2008, 08:24 AM   #8
87Wrangler454
87Wrangler454's Avatar
A link to this subject http://67-72chevytrucks.com/vboard/s...d.php?t=238020
87Wrangler454 is offline   Reply With Quote
Old 11-24-2008, 09:45 PM   #9
FRENCHBLUE72
PROJECT 7DEUCE
Thanks 87 for the link.
MEMBER #6377
Project "7DEUCE"
